Old 05-30-2015, 06:56 AM   #11
GalsofEscape's Avatar
Turn off the auto and should not switch.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
Old 05-30-2015, 06:45 PM   #12
Thank you. Can't try it now we are out camping but we have to put the pup up when we get home due to rain and I can try it then. Thank you
kinma13 is offline   Reply With Quote
Old 05-31-2015, 07:51 PM   #13
@ galore scape. What you suggested worked great. I turned the auto off and set to DC then unplugged and replied it in when I got home and it was still on DC without a check light. Thank you very much.
Old 05-31-2015, 07:53 PM   #14
Glad it worked and hope you had a great camping trip thus weekend.
Old 06-01-2015, 07:26 AM   #15
Well let's just say it was good because we were camping but it rained from Saturday around 3pm till Sunday around noon. Gist of wind every now n then. The pup it good though other then the cheap domestic awning rail where the leg attaches got a little bent. But no big deal still had fun with friends and the kiddo even loved it so that's a plus.
Old 06-01-2015, 07:44 AM   #16
But as they say, camping in the rain still beats any day at work, but putting away a wet camper sucks. One leg of my dometic awning leg broke off completely after the second time it blew over the top of the camper. I now tie the leg in place with parachute cord as the cost to replace that section is .
Old 06-01-2015, 08:01 AM   #17
vinmaker's Avatar
Interesting. I too thought it automatically switched from AC - to propane - to DC. In that order. I never realized it did not actually go to DC on auto mode. I do remember pulling into a site once and the fridge was not cold. That might have been why.
Kinma. What I usually do is have to cycle the fridge a few times to get the propane to work. I understand you do not like driving with the propane on. But if you do decide to try the propane option, this is what I do.
I open up the fridge vent door on the outside.
Unplug the unit from shore power and you will hear the pilot spark clicking.
I look to see if they propane ignites. ( most likely not)
I plug it back in and wait for it to switch over to A/C.
I unplug and look for the propane to ignite.
Repeat until you see the propane flame.
It can take 3-4 times normally for the propane to make its way to the fridge unit. A bit of a pain, but the whole reason I plug the unit in a couple days before leaving is to pre-chill the fridge. It would be a total waste of electricity if I just allowed the fridge to warm right up again.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-01-2015, 08:16 AM   #18
Galsofescape I tie it down every time just nor to tight. I had it go up n over the top once last year. Thank god no damage. I've heard that the poles can puncher the top so that would suck.
Old 06-01-2015, 08:22 AM   #19
Flybob's Avatar
Be careful using DC to power fridge. If it is left for any length of time, it will kill the battery. I have seen instances where it will also kill the TV battery. Some TV manufacturers have a relay that disconnects the 12V supply tot he Bargman when the vehicle is not running. If the fridge is full and cold, it should be OK for a few hour trip not running. The key word is full. There is very little in an empty RV fridge to absorb heat so it can heat up fast. Freeze a few water bottles and add them before final closing. They will help keep things cold and you can use them once they thaw.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-01-2015, 08:22 AM   #20
I tied it down after the first time, but the second time it managed somehow to break out of the traces lol. I now run a cord through the center piece and tie to the picnic table and tie down each of the legs- it ain't going anywhere now. And with bright pink cord lol
fridge
