Old 06-01-2015, 08:26 AM   #21
GalsofEscape's Avatar
Originally Posted by Flybob View Post
Be careful using DC to power fridge. If it is left for any length of time, it will kill the battery. I have seen instances where it will also kill the TV battery. Some TV manufacturers have a relay that disconnects the 12V supply tot he Bargman when the vehicle is not running. If the fridge is full and cold, it should be OK for a few hour trip not running. The key word is full. There is very little in an empty RV fridge to absorb heat so it can heat up fast. Freeze a few water bottles and add them before final closing. They will help keep things cold and you can use them once they thaw.
Yes, that can be an issue if you stop for a long lunch break. Keep any stops short.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 06-01-2015, 12:17 PM   #22
Good to know ty. Btw everyone how do you all pack the fridge? Any order or just cram it all in? The reason I ask is I put sausage on the bottom thinking cold sinks and then the fruit on the next shelf up in a bag but the fruit had frost on it and the sausage was just chilly not really cold. But that was the only thing on the bottom
kinma13 is offline   Reply With Quote
Old 06-01-2015, 12:31 PM   #23
I find items on the top shelf get really cold. They are right next to those fins. So I do put veggies or things you don't want to get real cold on the middle shelf. There is a mod people do to added those small fans in the fridge to help circulate the air and maximize cooling. It should also help with evening out the cold distribution.
Old 06-01-2015, 04:45 PM   #24
The fridge cools via convection air currents. The fins cool the air very close to them, the cold air sinks, cooling by conduction any objects in the path of the air sinking. As the cold air warms, it starts to rise again, eventually returning to the fins. The first object in the path of the sinking cold air (directly below the cooling fins) will get the most cooling.
Promoting a stronger convection air flow increases cooling. Objects in the fridge that are warmer than the cooling fins will increase convection - which is why a mostly full fridge will cool faster than an empty fridge. As Gals of Escape said, a fan to circulate the air in the fridge can promote convection flow even more.
Also, as stated, the cold food has a "hold over" effect similar to chunks of ice that helps hold the fridge at a cooler temp.
Fred W
Present: 2014 Rockwood A122 A-frame
Past: 2000 Coleman Westlake PUP
fridge
