Originally Posted by bubbles
This is made by Camco and may work. Don't know if connected and don't have "P" trap what odor effect it would have.
X-2
This is the right choice. The hose will droop to the ground and create a "trap" in the line to block sewer odors. The "gravity feed pressure" from your sink will overcome the small lift required to push the draining water uphill thru the yellow hose connection.
Before you break camp, run plenty of water through the sink to flush out the hose, because food particles will collect in the low spot in the hose. You may also wish to connect your drain hose to a garden hose at home and pressure wash it.
