Old 11-24-2013, 09:25 AM   #1
Tsm1977's Avatar
Furnace operation
I just bought a 228 MAC pop-up. At the dealer, the camper was fully hooked up and operational. Then it was "winterized" before I drove it home. When I got home, I opened it up and hooked up my electric and the propane. When I turned the heater on, it ran for a few seconds, then turned off. I turned it off and then tried again. Same result. Now it won't turn on at all. What did I do? How do I get the heat on?
Tsm1977 is offline   Reply With Quote
Old 11-24-2013, 09:30 AM   #2
Ford Idaho's Avatar
Do you have gas to the stove, try lighting a burner.
Does it work?
If not turn the gas off and then turn it on real slow.
Old 11-24-2013, 09:41 AM   #3
Tsm1977's Avatar
Yes, the gas stove works.
Old 11-24-2013, 09:44 AM   #4
Tsm1977's Avatar
I think I am missing a simple step. I'm just not sure which one.
Old 11-24-2013, 09:56 AM   #5
HONDAMAN174's Avatar
If you have a manual thermostat, see if the front face comes off. I had a similar problem where the fan would blow but not ignite. If the cover comes of, there should be some small dials. They control the ignite timing and fan duration. Take a picture of where they are just in case you need to put them back but play around with these controls to adjust the timing.
Just glad to get away
Old 11-24-2013, 09:58 AM   #6
I think you just have air in the propane line. it will take a few tries to get it out.
Old 11-24-2013, 10:13 AM   #7
Tsm1977's Avatar
The fan won't even blow. Before I take anything apart, is there a master on/off switch somewhere? I think it might be that simple.
Old 11-24-2013, 10:16 AM   #8
Fulltime family RVer
Do lights work? Could it be that you have a battery disconnect and nothing has power?
Old 11-24-2013, 10:17 AM   #9
Ford Idaho's Avatar
I would just unhook the battery ground and unplug it from any power outlet.
Old 11-24-2013, 12:18 PM   #10
Tsm1977's Avatar
I have no idea why, but it just started working!
