Old 05-23-2013, 07:14 AM   #1
furnace test
I would like to test my furnace, I dont have a 30 amp hook up so can I hook up the furnace using a extension cord hooking directly to my house to test I have a rockwood 1910 popup
kasper484 is offline   Reply With Quote
Old 05-23-2013, 07:19 AM   #2
TURBS's Avatar
Yes you can hook to the house.
Fyi your furnace is 12 volt.
Which is technically ran off of your battery when not hooked to shore power. in reality if your battery is charged you don't even need to hook it to the house to test it.
Turbs
Old 05-23-2013, 10:54 AM   #3
bradnailer's Avatar
Generally the only time you'd need 30 amp is when you are running your A/C.
2016 Ford F150 Platinum
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood 2560G Pop Up
bradnailer is offline   Reply With Quote
Old 05-23-2013, 02:51 PM   #4
bikendan's Avatar
yep, your furnace has no need of the trailer being plugged into shore power.
it runs off the 12v battery. the only thing that you'll need shore power for is the a/c, the 110v outlets, the 110v AC side of your fridge and recharging the battery.
did someone tell you that you needed to do this, to run the furnace?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
