Old 08-02-2015, 11:42 AM   #1
fuse lights on converter
There are red lights next to the fuses on my converter. What are these lights for?
Dragonfly213 is offline   Reply With Quote
Old 08-02-2015, 01:14 PM   #2
bikendan's Avatar
might help if you posted year/make/model of popup.
or posted pics of what you're asking about.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-02-2015, 06:31 PM   #3
In case they pop.......supposed to let you know they have blown.
Trevor43 is offline   Reply With Quote
Old 08-02-2015, 06:42 PM   #4
Cyber Phrenologist
Radio's Avatar
The LED should light to indicate a blown fuse.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 08-24-2015, 09:04 PM   #5
riddins's Avatar
Just has been said the light should show when a fuse is blown. On our unit I have seen several fuses blow and no red light. Not sure I understand why. Can any one help?
riddins is offline   Reply With Quote
Old 08-24-2015, 09:21 PM   #6
gashog's Avatar
One would think to test you could pull a fuse and the red led would lite for your blown fuse indicator. When I pull a fuse it doesn't light up on my Windjammer. So my panel possibly isn't working either???? From what I remember (could be wrong) my 2010 Keystone all the light were lite and when a fuse blew the red led went out. Could be totally wrong....
update:
I pulled the TV amp fuse the RED LED did not light up. It was because the AMP as not on and pulling any voltage. Turned the AMP button to its on position and the RED LED lite with the fuse removed. Tested some others same results. If the circuit is not using any voltage the lights won't light.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-24-2015, 09:37 PM   #7
Should be dark under normal conditions and light when blown, not all units have red lights as fuse blown indicators or any blown fuse indicators, Some units could also be wired so the red stays on unless it blows then they turn off,
2002 Rockwood Freedom 2318G
2004 Ford F 150 5.4 liter
3 Chihuahuas Sammy, Delilah,Gypsy
nineoaks2004 is offline   Reply With Quote
Old 08-24-2015, 09:49 PM   #8
Flybob's Avatar
There is a small circuit that detects that fuse is not conducting electricity by allowing a small leakage current to go through the circuit ( light etc) then lighting the LED. If there is not a path for the leakage current ( ie light shut off at switch) the LED will not light.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-25-2015, 08:01 AM   #9
riddins's Avatar
Now it all makes sense. and answers why you will see a small voltage in the circuit with the blown fuse.
converter, fuse, light
