Old 06-29-2016, 02:29 PM   #1
Gas pressure
I have a STOK gridiron grill I wanted to use on the propane lines on the side of my Rockwood HW276. After I got the adapters to connect to the disposable bottle connection on the grill, I tried to light it. There wasn't enough gas flowing to keep the burner running. Am I doing something wrong? The camper was closed when I tried it.
Sent from my SM-G935V using Tapatalk
chapboogie is offline   Reply With Quote
Old 06-29-2016, 02:32 PM   #2
Did you remove the pressure regulator from the grill? This is required since the regulator at the tank has already reduced the pressure at the gas line on the side of your camper.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 06-29-2016, 02:33 PM   #3
Is there a regulator on it?
Old 06-29-2016, 02:43 PM   #4
I wonder if I can disconnect it
Old 06-29-2016, 03:34 PM   #5
Not sure as I am unfamiliar with the grill.
Lee and Anne
Old 06-29-2016, 04:53 PM   #6
Check out youtube to see if there is a video on hoe to remove the grill regular
kinma13 is offline   Reply With Quote
Old 06-29-2016, 05:07 PM   #7
Oaklevel's Avatar
You can not have two regulators in line for the grill to work either the grills regulator must be gone or you need to hook your adapter between your propane tank and before your RVs regulator. An extend a flow kit works great for this but pricey.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-29-2016, 05:12 PM   #8
Oaklevel's Avatar
Try:
Camco 59125 Brass Tee with 4 Ports and 5' Hose - Walmart.com
or
Extend-A-Flow Propane Kit RV Camper - $61.14
see description
https://jet.com/product/detail/80fca...Q&gclsrc=aw.ds
I am sure it is available on Amazon as well
1966 Mustang GT
1986 Mustang SVO
Old 06-30-2016, 06:28 AM   #9
2gwright's Avatar
My camp Chef stove had an optional "RV" kit that replaced the existing hose and
regulator with a six foot hose that plugs directly into the camper port. As I recall it
was around $30 or so. The swap took about five minutes.
I looked at the owners manual for the Stok and it appears the regulator is part of
the control valve assembly. If this is true then your out of luck as bypassing the regulator would remove your controls as well as the ability to turn it off.
2015 HW296
2gwright is offline   Reply With Quote
Old 06-30-2016, 07:55 AM   #10
That's what I saw. Big bummer. This is a perfect family grill, and was a great father's day gift. Have to come up with a different solution.
gas, pressure
