Old 12-01-2019, 09:44 PM   #1
Amartin453's Avatar
Gas Regulator Needed
Having some difficulty finding the right regulator for my 2016 Rockwood Premier 2516G.
Please send me links as I’ve struck out locating one online!
What happened:
During our annual Thanksgiving camping trip, I believe my regulator was failing not properly regulating my appliances. The gas flow would only fuel one stove top burner. When I turned the gas on to a second burner both burners would fade out. Same thing happened when I tried starting the Click image for larger version
ID:	220075furnace and hot water heater.
Thanks.
A
Amartin453 is offline   Reply With Quote
Old 12-02-2019, 08:50 AM   #2
What happened:
During our annual Thanksgiving camping trip, I believe my regulator was failing not properly regulating my appliances. The gas flow would only fuel one stove top burner. When I turned the gas on to a second burner both burners would fade out. Same thing happened when I tried starting the Attachment 220075furnace and hot water heater.
Thanks.
A
Check here for info on buying direct from Forest River:
http://www.forestriverforums.com/for...al-188390.html
flyerdp is offline   Reply With Quote
Old 12-02-2019, 09:10 AM   #3
Try etrailer. Could this one work?
https://www.etrailer.com/Propane/MB-Sturgis/108221.html
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 12-02-2019, 09:54 AM   #4
Blackrock's Avatar
Have you tried your local Propane distributor? Mine has a wall full of regulaters and pig tail hoses.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 12-02-2019, 12:05 PM   #5
Amartin453's Avatar
Originally Posted by Jeffjeeptj View Post
I don’t think that will work because the vents are suppose to be down according to all the videos I’ve watched. Thank you for the link, I’ll try it if I can’t find the same one.
A
Old 12-02-2019, 12:07 PM   #6
Amartin453's Avatar
I sent FR an email with the pic asking for a quote. I’ll let you know the results once I hear back from them.
Thank you!
A
Old 12-02-2019, 12:57 PM   #7
A
How about this CAMCO one then...
Horizontal Two stage gas regulator.
Or this MB Sturgis from eTrailer...
MB Sturgis Horizontal 2-Stage Propane Regulator
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 12-02-2019, 05:30 PM   #8
The last regulator I bought for my previous camper I got from Walmart.
Ordered on line and had it in four days. Was Camco brand.
2021 Apex Nano 191RBS OFF GRID
2017 Chevy Colorado Z71 4x4 3.6 L
backpacker3 is offline   Reply With Quote
Old 12-02-2019, 06:16 PM   #9
This one from Amazon appears to be the exact same (just remove the tank fitting)
https://www.amazon.com/Cavagna-Group.../dp/B0711F7ZZR
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 12-02-2019, 07:47 PM   #10
Amartin453's Avatar
I appreciate all the responses, I think the regulator Titan Mike shared may get the job done!
A
Old 12-02-2019, 07:49 PM   #11
Amartin453's Avatar
Going tomorrow, I believe they may have it in stock. If not, Titan Mike shared one online that looks like it will get the job done.
Old 12-09-2019, 04:53 PM   #12
Amartin453's Avatar
Quick update:
After several online searches, one pluming supply shop and two RV dealers I located the proper part at the third RV center, La Mesa RV! Great customer service!
And the gas is flowing properly now!
gas
