Old 07-23-2014, 06:53 PM   #1
troutstalker's Avatar
generators -- the more I read, the more I ?
We mostly boondock camp and use very little power -- furnace fan a few times a night, water pump, few other vampire draws. Don't use the lights, the refridgerator or any appliances. Still, I suspect that one 12 volt battery isn't going to last a full five days. So I want to get a generator. Researched, researched and researched and I"m more confused than before.
All I simply want to know know is how small of a generator can I get to hook up to my battery every couple of days to charge? And do I need some kind of charger between generator and battery?
Anyone?
troutstalker is offline   Reply With Quote
Old 07-23-2014, 07:16 PM   #2
Plain Old Member
Can't go wrong with a Honda EU2000 inverter generator. You can charge directly from the generator. Pricey, but worth it to us. We run 2 in parallel with a piggy back tank. Don't use it very often, but with our set up, can run 30+ hours without refueling.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-23-2014, 07:20 PM   #3
MtnGuy's Avatar
With just charging the battery, the OP may get by with a 1000 watt inverter generator.
Old 07-23-2014, 07:20 PM   #4
John,
thanks much for responding. Can you tell me, how long does it take to charge up a battery with something like that? Couple hours?
Old 07-23-2014, 07:23 PM   #5
Plain Old Member
I wish I could tell you the answer to that, but don't have much experience on that portion of the generator. I don't know the exact charge output. MtnGuy mentioned probably getting by with a EU1000. Probably so after rereading what you need to run. Might research the Honda site on the specifics of the generator and it'll probably tell you. Someone will probably chime in shortly that has more experience in that area.
Old 07-23-2014, 07:31 PM   #6
Plain Old Member
DC output says 8 amps for either one. I'm guessing that'd be the charging amps. Not 100% sure.
Honda EU1000i Model Info | Super Quiet 1000 Watt Inverter Generator | Honda Generators
Honda EU2000i Model Info | Super Quiet 2000 Watt Inverter Generator | Honda Generators
Old 07-23-2014, 07:40 PM   #7
So that would be 8 amps an hour at that rating?
mbm
Old 07-23-2014, 07:43 PM   #8
KyDan's Avatar
Cheaper option is 1000 watt genny. (Some are more quiet than others.)
With a 25 amp automatic charger plugged into it the genny would be loafing.
Peace!
Dan & Rita D
Blue Ox WD hitch
2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75
KyDan is online now   Reply With Quote
Old 07-23-2014, 08:08 PM   #9
Iwannacamp's Avatar
Battery amperage/charger output. I would not charge more than 10 amps per hour on a battery I cared about.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 07-23-2014, 08:42 PM   #10
John McClain's Avatar
If its an AGM battery you can charge it faster and at a higher amperage. like 20 - 25 amperage. We have both Honda and yamahas and run both of them, tell the wheels fall off.
The Yamahas are a little better built.
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
generator
