Old 06-17-2016, 06:37 AM   #101
Originally Posted by kinma13 View Post
Spurticus I have a similar setup when camping for a week or so. But for weekends I just use 1 stinky slinky and just switch after the black is empty. I use a a clear elbow between the pup connection and the ss. The clear elbow is a hydro flush so I can clean the ss b4 I disconnect to switch.
I have a hydro flush hooked up at the black tank. Didn't think about it for the hose itself. I will probably keep it simple like you said for shorter trips. For the week trips though, I will use this set up and be done.
spurticus is offline   Reply With Quote
Old 06-17-2016, 06:39 AM   #102
Prime Member
Hydroflush
Please don't tell me that's your drinking water hose I see in the photo.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-17-2016, 06:43 AM   #103
Initial set up only. Everything was rearranged once we got going. The darker garden hose is still there. That's the cleaning and flushing hose. There's no mistaking the two.
Old 06-18-2016, 02:33 PM   #104
Not my actual hydro. Stole to pic from the internet. But NO I don't use a drinking hose. I use the same hose I use for my swivel stick wand.
kinma13 is offline   Reply With Quote
Old 06-25-2016, 09:02 PM   #105
Thanks to this thread I have finally been able to take care of my biggest frustration with the purchase of our Rockwood Pup! Stupid design!
wolfixum is offline   Reply With Quote
Old 06-26-2016, 09:46 PM   #106
Would you be willing to share the parts list for your adaptor? I apologize if you already listed the parts and I have missed it.
sgreats is online now   Reply With Quote
Old 06-26-2016, 09:51 PM   #107
Look at the 3-4 thread. Part list is there.
Old 06-27-2016, 04:51 AM   #108
I made the same adapter. The parts were ordered online from Lowe's. Its all ABS plastic. Some Lowe's stock it, some don't. Depends on where you live.
Old 06-27-2016, 06:17 AM   #109
Sgreats
Lowes numbers in white
23301, 23319 then it's a valterra T2901-1. You can gets lowes parts in black but only at some stores and not sure the numbers.
Old 06-27-2016, 06:19 AM   #110
Sgreats look at fishhawks list but he did have 1 number wrong at first but should have corrected it in a later post
drain
