Old 08-01-2014, 09:16 AM   #21
Fishhawk1650's Avatar
Pic all pushed together and cemented
Name:	ImageUploadedByForest River Forums1406902594.706290.jpg
Dan
Fishhawk1650 is offline   Reply With Quote
Old 08-01-2014, 10:26 AM   #22
The michigan stores dont have these in black. Cant even order them. Sucks
kinma13 is offline   Reply With Quote
Old 08-01-2014, 10:45 AM   #23
Fishhawk1650 does your local store have them in stock?
Old 08-01-2014, 10:54 AM   #24
Hey fishhawk1650 looks like I found some but can you check the part numbers you have? The link is described to be the right parts in black but the pic are the same at lowes. I ordered the amazon already. So glad u found in black
Old 08-01-2014, 11:03 AM   #25
Here is how i solved the the problem between bot gray and blackwater dumping
[ATTACH][ATTACH]Click image for larger version
ID:	59432   Click image for larger version
bleurt is offline   Reply With Quote
Old 08-03-2014, 06:46 PM   #26
Apologies for the delay, just got back from camping :-)
Those were the part numbers on the receipt. The pic on the website for the 1-1/2 to 3" coupler does not match but that was the part number.
I saw the black ABS first before spotting the previous parts listed in the thread. From there, just scanned and grabbed the ABS counterparts and rolled with it. On the shelf, they seemed grouped by diameter size making it a little easier to spot in the sea of plastic.
After dumping this afternoon, I can happily report the fitting worked flawlessly!
Cheers
Old 08-03-2014, 07:03 PM   #27
Cool. Ty just didnt want to specail order the wrong stuff that they messed up. Yeah it said the right stuff so I figured it was all right. Btw glad to here it all worked great. I was thinking of useing a Y connector at the black outlet n tie the grey in but it looks like it would be about 3ft and the only slinky I find is 2' or 5" so think ill just use the slinky after I dump the black. Thank you for getting back.
Old 08-05-2014, 09:19 PM   #28
One part number is wrong. http://m.lowes.com/pd_22765-137-CL58...803&facetInfo=
It's non threaded 1.5" on one side. When put next to the reducer, they are both female. I'm going to need a very short piece of pipe to put inside to connect these two.
mtaylor42 is offline   Reply With Quote
Old 08-05-2014, 09:20 PM   #29
Your pic shows a part that can be put inside the reducer.
Old 08-05-2014, 09:24 PM   #30
Mtaylor42: I dont know the part number but is called a 1 1/2 clean out.
drain
