Old 08-06-2014, 02:19 AM   #41
Yeah I think im gonna do it ur way seam like not to much of gravity dont know we ll see
kinma13 is offline   Reply With Quote
Old 08-06-2014, 08:19 AM   #42
Here's my two cents on HW 276 grey water dilemma. I took the hose rinser, drilled a 2 1/8 inch hole,largest bit I had, thru it,used Rotary hasp in my cordless drill to enlarge hole to accept the 1 1/2 inch PVC adapter
GB guy is offline   Reply With Quote
Old 08-06-2014, 08:25 AM   #43
Sorry for the premature post, I then epoxied the two together, haven't tried it yet, but see no reason it won't work, this way I just switch the slinky from black to grey, and no waiting for the garden hose to take forever to drain. I don't understand how Forest River could do so many things right, and be so wrong on this issueClick image for larger version
Name:	ImageUploadedByForest River Forums1407327904.418049.jpg
ID:	59807Click image for larger version
Name:	ImageUploadedByForest River Forums1407327924.561241.jpg
ID:	59808Click image for larger version
Name:	ImageUploadedByForest River Forums1407327933.338221.jpg
Old 08-06-2014, 09:18 AM   #44
GB guy I was looking at doing that setup but was afraid the epoxy wouldnt hold but let me know if it does. Why didnt the just tie both grey n black together like most TT. or even install a tank rainser in the blk. Wish I was going to goshen
Old 08-06-2014, 10:05 AM   #45
vinmaker's Avatar
Originally Posted by Fishhawk1650 View Post
Success!
Parts used are all black ABS
1 1/2" clean out
Shop NIBCO 1-1/2-in Dia ABS Adapter Fitting at Lowes.com
1 1/2" to 3" coupler
Shop 3-in x 1-1/2-in Dia ABS Coupling Fitting at Lowes.com
Valterra 3" T1029-1 termination adapter
Amazon.com: Valterra T1029-1 Termination Adapter with 3" Bayonet x 3" Spigot: Automotive
Loose assembly before tightening up and cementing
Attachment 59405
I am so gonna do this. Thanks for the parts list. SO the Valterra part will slip right into the 3" coupler? Just use a bit of PVC glue to hold it all together?
I like this option as I can simply unscrew it and store it away. It also makes switching from black to grey very easy and I can flush the hose clean grey.
Vin.
Old 08-06-2014, 10:25 AM   #46
Yes vin it should all go together and pvc glue it. Just make sure you get the 1 1/2 " CLEAN OUT I guess it was wrong on the orig list. Just see pic in previous comments.
Old 08-06-2014, 10:36 AM   #47
vinmaker's Avatar
Yeah. I know that I need the threaded end for my discharge pipe and a smooth end to glue into the 3" reducer.
I'll put the thing together in the store isle to make sure it all fits nice. Just wanted to make sure that the outside diameter of the Valterra will fit the inside diameter of the 3" reducer.
Vin.
Vin.
Old 08-06-2014, 02:11 PM   #48
Fishhawk1650's Avatar
That was the biggest mystery for me, whether or not the Valterra termination fitting will fit into the 3" increaser/reducer. It fit like a glove.
I already had a rinse out end cap and am using this as the cap for the new fitting. I can find a pic of it later if you need a reference, but any cap should do (think the cap you already have for your black gate)
Fishhawk1650 is offline   Reply With Quote
Old 08-09-2014, 05:20 PM   #49
Mine looks great! Thanks again for the idea and the parts list.
mtaylor42 is offline   Reply With Quote
Old 04-29-2015, 06:11 PM   #50
vinmaker's Avatar
Fish,
I looked at the link on the 1 1/2 inch clean out and it does not look like it would fit into the coupler end. They both look like they are 1 1/2 in. I need one to be inside dia and one outside dia.
I am going to order the Valterra piece now on Amazon. Just need to get the other two at loews.
Kinma. Did you ever get yours built?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
drain
