Old 06-16-2015, 07:05 PM   #71
Originally Posted by vinmaker View Post
That is interesting. I was just thinking I would remove it and store it. But why? I think your right. Just keep it on there.
I take it you put a 3" termination cap on it.
Vin.
Hey vinmaker this doesn't go but how do you level ur pup hw296? Side to side?
kinma13 is offline   Reply With Quote
Old 06-17-2015, 06:23 AM   #72
2gwright's Avatar
Hey Kinma13,
I also have a HW296 and I use two Anderson Levers. Works like a champ.
I did have to cut one of them down to fit between the tires.
To stay on subject, I choose to cut and rework the factory plumbing to
have a single connection dual waste valve setup. I had my first trip of the
season and the modified waste plumbing worked like a champ. On July 4th
we will stay in a site with sewer hookup and it will be even easier.
2gwright is offline   Reply With Quote
Old 07-19-2015, 08:42 AM   #73
Green horn
Stebbie's Avatar
This is my new grey water dump set up. Picked up all necessary parts at general rv here in Michigan. Wanted to extend over to the black tank and have only one connection but have a few issues with that. First black drain is facing rearward more than id like, grey drain is lower than the black and my sewer hose tube is directly between the two.
ID:	83327   Click image for larger version
Stebbie is offline   Reply With Quote
Old 07-19-2015, 08:41 PM   #74
Fishhawk1650's Avatar
Looks perfect Stebbie! Nice work ;-)
Fishhawk1650 is offline   Reply With Quote
Old 07-23-2015, 09:18 AM   #75
I've been getting several questions about this installation and unfortunately the forum doesn't allow me to edit the original post that had incorrect part URLs.
The original receipt had errors for the part numbers and furthermore the Lowes web page is not reliable for finding these parts.
Please use this picure as a reference point for parts. I'm travelling right now and when I get back to Lowes, I'll look for the right part number on the shelf and post them. Hopefully they still have them!
Apologies in advance for any confusion.
Originally Posted by Fishhawk1650 View Post
Success!
Parts used are all black ABS
1 1/2" clean out
1 1/2" to 3" coupler
Valterra 3" T1029-1 termination adapter
Amazon.com: Valterra T1029-1 Termination Adapter with 3" Bayonet x 3" Spigot: Automotive
Loose assembly before tightening up and cementing
Attachment 59405
Old 07-23-2015, 01:47 PM   #76
My Lowes did not have the parts so I ordered on line. Received the 1 1/2 to 2 cleanout parts yesterday....2" to 3" Reducer Adapter prolly today...Valterra 3" termination adapter scheduled for Saturday. Went for 2 sets in case of....well you know.
Big 4 day, full hook-up, 4 hour drive trip planned for next week.
How's everyone's holding up and working?
Greg
Tree Rat is offline   Reply With Quote
Old 07-23-2015, 08:08 PM   #77
Ok, there's a Lowes in the location where I'm visiting and checked their parts. They only had the white pvc and not the black ABS. These two items fit together perfectly.
1-1/2" cleanout - Item 23301
Shop Charlotte Pipe 1-1/2-in Dia PVC Cleanout Adapter Fitting at Lowes.com
1-1/2" to 3" coupler - Item 23319
Shop Charlotte Pipe 1-1/2-in x 3-in dia PVC Adapter Coupling Fitting at Lowes.com
When I get back to CO, will check my local Lowes for the ABS part numbers.
Dan
Old 07-24-2015, 08:58 AM   #78
New to site, just completed drain cap from the 1 1/2 inch to 3 inch, cost around $9.00 and ten minutes of my time. This should work great, will find out next week on our first trip. Thanks for all the great ideals that are being shared on this site.
2014 Flagstaff 228 with shower
JPBar is offline   Reply With Quote
Old 07-26-2015, 03:48 PM   #79
Here are the parts for black ABS
1-1/2" cleanout- Item 22789
http://www.lowes.com/pd_22789-137-CL...ductId=3468441
1-1/2" to 3" coupler - Item 22806 *Note, picture on the website is wrong, but is the correct part!
http://www.lowes.com/pd_22806-137-CL...ductId=3434756
Dan
Dan
2014 HW276
2003 F150 Supercrew
Old 07-26-2015, 09:45 PM   #80
Put mine together today....did two sets. Fit was great. Installed looks OEM.
Awesome solution to a dumb design. Thanks to all who put this idea out.
Greg
drain
