Old 07-29-2014, 12:32 PM   #1
Grey drain outlet setup
I setup a different connection and now I can go from the 1 1/2 outlet to a 3" stinky slinky. no more 30 min drain using a 3/4 garden hose.
kinma13 is offline   Reply With Quote
Old 07-29-2014, 07:24 PM   #2
vinmaker's Avatar
Nice. I use a pool vacuum hose with my grey water drain. Lots faster than a hose.
I like your set up. Should drain real fast.
Old 07-29-2014, 07:36 PM   #3
Fishhawk1650's Avatar
Thank you for sharing the pic! I'll give this a try :-)
Fishhawk1650 is offline   Reply With Quote
Old 07-29-2014, 08:10 PM   #4
Fishhawk1650 all from lowes. Its pvc "charlotte" pipe. I have part numbers but they are on my cell and its dead right now. Ill post later
Old 07-29-2014, 09:06 PM   #5
Fishhawk1659 here are the item numbers
3" x 1 1/2" reducer / increaser
Charlotte pvc-dwv
Item # 23319
3" x 2' ips sch 40 pvc dwv pipe
Item # 294917
Charlotte pipe 1 1-2" dia pvc cleanout
item # 23301
Old 07-29-2014, 09:23 PM   #6
Green horn
Stebbie's Avatar
Thanks for the pic. Definitely want to try this.
Stebbie is offline   Reply With Quote
Old 07-29-2014, 09:48 PM   #7
Pill Billy's Avatar
Nice mod. Thanks for taking the time to post the part numbers.
Pill Billy is online now   Reply With Quote
Old 07-29-2014, 10:38 PM   #8
loobdyloo5's Avatar
We went with this set up for r pop up. We also have a fernco piece to a 3" for a standard campground hookupClick image for larger version
Name:	ImageUploadedByForest River Forums1406691408.147506.jpg
ID:	59247Click image for larger version
Name:	ImageUploadedByForest River Forums1406691486.025774.jpg
loobdyloo5 is offline   Reply With Quote
Old 07-29-2014, 10:49 PM   #9
Thank you so much for posting the parts list!
Old 07-29-2014, 11:19 PM   #10
I wonder if instead of using the 3"x2' pipe and cutting to go into the reducer, to use this
Termination Adapter, 3" Bayonet x 3" Spigot - Valterra.com | Valterra.com
That way there's a bayonet end where the sewer hose can lock on.
drain
