Old 10-31-2006, 10:10 PM   #1
beewookie's Avatar
Grey water ports - replacing OEM threaded hose connections
The Pup is winterized and in the garage - time for mod season!
Has anyone replaced the OEM threaded hose connections for the grey water hoses for the sink and shower?
The threaded PVC pipes on the pup uses a threaded collar and garden hose sized "funnel" for a simple hose connection. I had problems with kinks and slow drainage since a 90 degree angle is required to drain to the tote. I tried PVC elbows for the smaller hoses.
My thought was to find a 1 and 3/4 inch PVC pipe with elbow along with the threaded collar to maintain the larger pipe for better drainage into the tote. Maybe using a larger shop vac type hose for drainage.
Has anyone adapted any PVC plumbing, pipes and hoses to do the same?
Bill
Tent (10') Feet
Chevy 3/4 Ton Diesel Pickup
Forest River Flagstaff 205
Fantastic Fan, Heated Bed Mattresses, Forced Air Furnace, 3 Way Refrigerator, Awning, Built-in Charger, Lined Privacy Curtains, Roof Valances, Patio Light, 110 Exterior Outlet, Spare Tire, Tire Bracket, Tire Cover, Step, Shower/Cassette Toilet Option Incl Water Filtration System, 6 Gallon Hot Water Heater, Demand Water Pump, Outdoor Shower, RVQue, Kitchen Pantry, Power Lift System.
beewookie is offline   Reply With Quote
Old 04-21-2009, 03:04 PM   #2
I have seen where people use 1 1/4 to 1 1/2 in sump pump hose attached to PVC nipples that screw onto the 1 1/2 inch threaded pipe to drain thier grey water into all sorts of containers, totes and CG sewer systems. I own a 2005 2318G and am going to try this out myself as it doesn't look to difficult or expensive.
Cory
CamperKidz is offline   Reply With Quote
tent camper
