Old 05-13-2012, 08:24 PM   #11
Originally Posted by rawlus
In my experience the do not get "hot" to the touch, they use the same technology as radiant floor heat (made by a radiant floor heat company) so its more about not being cold to the touch than it is about being hot.
They feel and work differently than an electric blanket.
Mattress pads, memory foam covers, etc will reduce the sensation of heat.
Very good description of how they work...
2010 Flagstaff 625D
2011 Dodge ram 1500
jpetrey is offline   Reply With Quote
Old 03-23-2014, 04:58 PM   #12
BigMac
bmcilravey's Avatar
Also...we found after we read the manual that these do not actually start to heat until you are lying on them...so you can't really "pre-heat" them. They activate when you are on them.
bmcilravey is offline   Reply With Quote
Old 03-27-2014, 10:55 PM   #13
MI Camperz
bodzcampers's Avatar
Ours works before hand, but maybe it's the weight of the pillows and comforter that is setting it off.
MI Camperz
bodzcampers is offline   Reply With Quote
