Old 04-16-2014, 09:55 PM   #11
delb2917's Avatar
Ok. I took out the fuse and put it back in and the heater kicked on and then the pilot light and I'm getting heat. But... what is the button on the left in the middle picture? Its not for my fridge I dont think.
Sent from my SCH-I535 using Forest River Forums mobile app
delb2917 is offline   Reply With Quote
Old 04-16-2014, 09:57 PM   #12
delb2917's Avatar
The button in the picture is for my water pump.
Old 04-16-2014, 10:00 PM   #13
great work sounds like you're having some success figured it out
Sistahazel is offline   Reply With Quote
Old 04-16-2014, 10:07 PM   #14
delb2917's Avatar
Yes and I feel like a total toolbag. I have never done any of this stuff yet. Just popped it up a couple times. Thats it.
Old 04-16-2014, 10:07 PM   #15
delb2917's Avatar
How long do I have on one propane tank?
Old 04-17-2014, 05:21 AM   #16
I camped for 3 days straight used my heater at night and during the day with grilling and still had propane left
Old 04-21-2014, 01:01 PM   #17
gettawaydriver's Avatar
Many heaters like that have a DSI (direct spark ignition) that only lights when thermostat tells it to run. If it doesn't get propane to fire in a few seconds it faults and shuts down. To get it going again shut it off then back on again and the fault will clear. Just do this once or twice and propane should reach the burner and light. The DSI should be audible while it attempts lighting and ignition also a noticeable sound.
Propane should last couple days per 20lbs bottle in cool temps but the problem will be the blower fan. It sucks back a lot if power and if on battery 12v it won't last as long as the propane. Also, and make special note of this, it has been my finding that this deficient battery event will almost certainly coincide with the coldest night at the darkest hour and likely in the rain while you are at the peak of need for sleep. I'm sure the popup engineers designed it this way laughing to themselves as they drifted off to sleep in their warm beds hugging their soft pillows goodnight. There are many solutions to this predicament but none that are consoling at the time. Just remember: it's all part of the fun.
gettawaydriver is offline   Reply With Quote
Old 04-21-2014, 02:43 PM   #18
delb2917's Avatar
Thanks.
heater
