Old 04-16-2014, 08:57 PM   #1
delb2917's Avatar
Heater
Question. I turned on my propane tank and tried to light the pilot light and nothing is happening. No spark. And ideas?
Sent from my SCH-I535 using Forest River Forums mobile app
delb2917 is offline   Reply With Quote
Old 04-16-2014, 09:09 PM   #2
give us a little more information about what we're talking about make, model, year? there should be a thermostat somewhere that controls the heater. if the thermostat is not telling the heater to turn on, there won't have a spark
Sistahazel is offline   Reply With Quote
Old 04-16-2014, 09:13 PM   #3
delb2917's Avatar
Its a 2012 flagstaff. I put the thermostat to the highest setting and the followed the directions by the ignition and no spark.
Old 04-16-2014, 09:17 PM   #4
so with the gas on and your thermostat turned up do you hear the heater blower kick on at some point?
Old 04-16-2014, 09:18 PM   #5
Did you try lighting the stove to see if you're getting LP flow? Maybe you turned the LP tank valve on too quickly. Try turning it off, waiting a few minutes, then turn it back on slowly and try your furnace again. Does your thermostat have a battery? Does it have a good charge?
Old 04-16-2014, 09:31 PM   #6
delb2917's Avatar
Yes stove works.no battery on thermostat. And I have camper plugged into garage. Here are pics. Please help!!!
ID:	50012   Click image for larger version
ID:	50013   Click image for larger version
Old 04-16-2014, 09:39 PM   #7
I have a 2004 Flagstaff pop up and mine looks pretty much the same. if your thermostat is working properly it should do two things once the thermostat is raised up: turn on your blower then start a time sequence for the igniter the starting igniting. sounds it as is the thermostat may not be working..
Old 04-16-2014, 09:41 PM   #8
delb2917's Avatar
Is the switch on the left in the middle picture to turn on heater.
Old 04-16-2014, 09:46 PM   #9
no those controls are for your refrigerator. if your stove is working that means you're getting gas. did you find out if the blower fan motor is turning on when you raise the thermostat.
Old 04-16-2014, 09:49 PM   #10
heater
here's a hey manual for the fridgerator that you describe the controls for you
heater
