Old 02-10-2011, 09:27 AM   #1
Heater Question
New Member. Hello all! So we purchased a 2009 Forest River Rockwood Premier 2317G about two weeks ago. Took it out that very day and had a great time. Of course, being newbies, we have a few issues. QUESTION: The heater on the camper comes on when we hook the camper to the car for towing. Before I closed it up the last time I turned the themostat all the way down. I did not realize that it would still come on when, in cold temps, when connected to the cars electric. Would should I do to stop this as I see no reason for the interior of the folded down camper to be heating up while we are towing it. Further, it seems a waste of propane and dangerous. Please help. Thanks.
ritondo is offline   Reply With Quote
Old 02-10-2011, 09:32 AM   #2
acadianbob's Avatar
Turn off your propane? If you are using your refrigerator, you may have a 3-way that can run off of your 12 volt supplied by your vehicle. Your trailer is a pop-up? Our pop-up had another switch on the thermostat to totally shut it off. Check to see if you have one. Ours was on the bottom of the thermostat.
Our pop-up was a Rockwood Premier 1907 so could be similar to yours.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-10-2011, 09:33 AM   #3
MtnGuy's Avatar
Make sure there is no on/off position with your thermostat. On some thermostats you have go beyond the lowest setting, and it "click" to off.
If there is no on/off position, pull the fuse for the furnace in your power center.
BTW, welcome to the forum !!!
Old 02-10-2011, 11:11 AM   #4
That is the way ours works - had the same issue until we learned to push it down until we heard the click.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
