Old 04-09-2015, 11:05 AM   #1
Heater won't start now
Hi guys!
FROG newbie question again:
So I can't get our heater to start up. One tank ran out overnight, and now I can't get the heater to startup again. Is there a pilot light that I need to restart that I haven't found yet?
P
toddpeperkorn is offline   Reply With Quote
Old 04-09-2015, 11:14 AM   #2
Steve Jackson
sideout1961's Avatar
You might need to bleed the line again. Try starting a burner on the stove and let it burn for a few seconds and try the heater again. I have to do this sometimes when my refrigerator won't light. Sometimes it tough to get the stove top to light.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-09-2015, 11:17 AM   #3
R&J Silverback's Avatar
I think sllideout1962 is right on this
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 04-09-2015, 11:23 AM   #4
Flybob's Avatar
If the above doesn't work, try this.
Shut off both tanks
wait 5 mins.
Turn on full tank very slowly especially where it first opens valve.
Run the stove to bleed the lines
Try furnace again.
If the tank valve is opened quickly after the lines are depressurized, the safety valve will shut off flow as it thinks there is a major leak or disconnected line. The above procedure will reset it.
Are you not using your auto switchover?
Most furnaces will go into safe mode after 3-4 fails while trying to light. If this has occurred. Turn furnace off (not just down) wait a minute then turn back on to reset.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-09-2015, 03:41 PM   #5
f5moab's Avatar
Other answers could be a problem, but also the cheap thermostat that comes from the factory could be another problem. On mine, sometimes it won't come on, and I have to switch it off/on a few times to make it kick in. That's my next replacement after batteries....
f5moab is offline   Reply With Quote
Old 04-09-2015, 04:01 PM   #6
Oakman's Avatar
As others have stated be sure you have bled air out of the line. Also turn the thermostat to off, wait a second and then back to furnace.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-09-2015, 09:21 PM   #7
papasmurff1's Avatar
Cut your thermostat all the way off you will feel a click then turn it back on. It will reset itself. Happened to me on the last camp out.
papasmurff1 is offline   Reply With Quote
Old 04-10-2015, 01:49 PM   #8
I had a problem where I had the heater one night and then in the morning it would not start up again, there was a pilot light though.....it turned out to be a fuse hidden inside the line just on the other side of the metal screen
Vicfut is offline   Reply With Quote
Old 04-10-2015, 02:06 PM   #9
ColoradoRick's Avatar
Wow, great tips...I'll store those for future use, if needed!
I, also, bleed the stove gas when starting the refrigerator...really speeds up how long it takes for the gas to kick on. (I'm glad we can hear it...helps ensure it's on.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
heater
