Old 08-27-2018, 11:59 AM   #1
Help with broken fitting
So I found a leak coming from a fitting in my water line on my 2006 1640LTD Rockwood. What I thought was just a coupling though turns out it's like an in-line check valve?? Is this normal to have , does everyone have one? The reason I ask is I can't seem to find a local parts store that carries them and this leads me to believe maybe it's not a common setup? Think I'm ok just to replace it with a coupling to get up and running for a few days? I've attached a pic of the fitting.
craigrazz is offline   Reply With Quote
Old 08-27-2018, 12:02 PM   #2
Retired and Loving Life!
Alan F's Avatar
Send a message via MSN to Alan F
No picture attached. Is it the check valve for the black tank flush? They are prone to leak
Alan F is offline   Reply With Quote
Old 08-27-2018, 12:32 PM   #3
That's weird, not sure why it didn't attach. Let's try again.
No it's on a freshwater line.
Old 08-27-2018, 12:33 PM   #4
pic
Old 08-27-2018, 12:39 PM   #5
More info needed. Where does that line supply water too ??
Decon Blue is offline   Reply With Quote
Old 08-27-2018, 02:30 PM   #6
just the faucet
Old 08-27-2018, 06:03 PM   #7
Just search for Barbed Check Valve of the size needed and you'll find plenty. Uline has plenty of them.
Having said that, I'm not sure why it's there, unless the faucet folds down into the sink, then it would be used as a backflow preventer in case water got left in the sink and the faucet got folded down.
Gotta go campin!
Old 08-28-2018, 08:50 AM   #8
I suspect that is the check valve that prevents your water connection from filling your fresh water tank...
Without that in place, as soon as you turn on the water you'll fill the fresh water tank and overflow it.
Assuming the setup is the same as on my 1640ESP...
jr1221 is offline   Reply With Quote
Old 08-28-2018, 11:20 PM   #9
Splitshaft's Avatar
There is usually a check valve "somewhere" at the city water inlet. The reason for a check valve at the city water inlet is so the 12V water pump does not pump water out that connection, especially when it is only capped with a rubber plug that would blow out!!! The 12V water pump its self has check valves to prevent reverse water flow so city water does not fill and over flow the fresh water holding tank. Simple fix. Just get another in line check valve for the cracked one and all is good. No worries.
Splitshaft is offline   Reply With Quote
Old 08-29-2018, 07:57 AM   #10
Thanks for the clarification Splitshaft! I had it backwards in my head...
Old 09-04-2018, 07:29 PM   #11
rlh1957's Avatar
Home Depot, WalMart, Lowes and that fails, piece one together with what they do have.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 09-04-2018, 07:30 PM   #12
rlh1957's Avatar
Sometimes in the sprinkler section you can find small inline check valves.
24WS
FX4 Off Road (4X4)
