Old 03-18-2015, 05:01 PM   #1
jos
Hi new here, looking for some help? We bought a used 2008 flagstaff PPP up and the cei
The lights will work then get dim, then go off after awhile they just start working again? Any help...
jos is offline   Reply With Quote
Old 03-18-2015, 05:06 PM   #2
fonzie's Avatar
Make sure your battery is fully charged.
Fonzie
Old 03-18-2015, 05:25 PM   #3
jos
So the ceiling lights work off the 12 volt battery? I assumed they worked off the electrical terminal? We ran the ceiling vent fan all day, so I am guessing that has drained the battery causing it to drain?
Old 03-18-2015, 05:28 PM   #4
fonzie's Avatar
Lights and vent fan all 12 volts. Are you plugged in to shore power? If you are plugged in, the converter should be charging your battery.
Fonzie
Old 03-18-2015, 05:53 PM   #5
jos
Maybe the converter is not working...
Old 03-18-2015, 05:55 PM   #6
fonzie's Avatar
Do you have a multi-meter to check your battery? When battery is being charged, it should read about 13.5 volts and above.
Fonzie
Old 03-18-2015, 05:58 PM   #7
TURBS's Avatar
Sounds like the converter is over heating.
Also sounds like battery is junk.
Old 03-19-2015, 10:09 AM   #8
jos
Does the converter have its own battery stored inside it? After checking everything I possibly can the celling lights and vent fan will not work, checked fuses and the converter seems to be working...
Old 03-19-2015, 10:13 AM   #9
TURBS's Avatar
Converter takes 120v and converts it to 12v to charge your battery.
Have you done any testing with a multi meter?
What brand and model converter do you have?
Old 03-19-2015, 10:21 AM   #10
jos
Unfortunately I don't have a multi- meter... The converter is a WFCO 3 stage converter...
flagstaff
