Old 07-04-2016, 04:54 PM   #1
Highwall low clearance- help?
Our new Flagstaff Highwall 2016 seems very low to the ground. It scrapes our driveway at the step and the bars at the back of the trailer. Anyone have same issue? What can we do?
Mark C is offline   Reply With Quote
Old 07-04-2016, 07:05 PM   #2
How steep is your driveway?
Trevor43 is offline   Reply With Quote
Old 07-04-2016, 08:12 PM   #3
MiCamper6's Avatar
Is it level when hooked up to your tow vehicle?
MiCamper6 is offline   Reply With Quote
Old 07-04-2016, 08:26 PM   #4
Pics
It scrapes when in tow. There are a few tricky transitions. The street slopes down, then there is a dip at the transitions to the sidewalk and then another transition to the start of our driveway. The back scrapes at the street/sidewalk transition and the stairs scrape on the driveway. Here are two pictures. Welcome all suggestions!!!
Old 07-04-2016, 08:27 PM   #5
Another
From the other angle.
Old 07-04-2016, 09:24 PM   #6
MiCamper6's Avatar
If your camper sits tongue high when hooked up it will reduce ground clearance in the rear. If so, you need to get the proper drop on your hitch.
Old 07-05-2016, 07:48 AM   #7
Sham183
mopwr4me2003's Avatar
What does it look like hooked up? I have a steep driveway to the road and until I got the right drop for my hitch I was tearing up my driveway. I will post a pick if I can of how steep it is so you get a idea. We leave tomorrow for a trip and I should have it hooked up tonight or early tomorrow. I would scrape going out and coming in. I don't have a HW but still the same principles are there.
mopwr4me2003 is offline   Reply With Quote
Old 07-05-2016, 08:51 AM   #8
MiCamper6's Avatar
It would also be helpful if you could start making your turn onto the street as soon as possible so that you minimize the transition from the driveway to the street. It is very important to have the correct drop on your hitch though!
Old 07-05-2016, 09:10 AM   #9
GalsofEscape's Avatar
The rear stabilizers always scraped with our highwall when we backed in. It was fine pulling out. We would lay some boards in the gutter that when the popup tires went on them would lift the back end enough so that the back stabilizers would clear. Was a pain but it worked for us.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 07-05-2016, 09:16 AM   #10
I have a similar problem with our HW. The chains drag and the bottom of the tongue jack gets awfully close to the ground pulling out of our sloped driveway. I found it helped to drive out on an angle as soon as I cleared the garage. As far as correct hitch height, see attached photo and a great Curt video.
Name:	ImageUploadedByForest River Forums1467728122.602588.jpg
spurticus is offline   Reply With Quote
Old 07-11-2016, 12:02 PM   #11
vinmaker's Avatar
My Rockwood height is fine. The only thing I can think of is that your driveway is too steep. Not what you want to hear I am sure.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 07-28-2016, 03:42 PM   #12
That is as bad as my driveway. I have to come and go on a big angle and creep. I still scrape the bottom. It is the best I can do unless I spend a small fortune on a new driveway.
Dodaman is offline   Reply With Quote
Old 07-28-2016, 05:21 PM   #13
Does it drag if you do not hook up the bars on the WD hitch?
BBQGUY is offline   Reply With Quote
