Old 04-29-2014, 01:10 PM   #1
loumichelle735's Avatar
Hitch.
Can anyone tell me if it a good idea or not to add a 2" receiver to the back of my pop up? It would be used for a bike rack or hitch haul to add some extra capacity. Thanks in advance!
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
loumichelle735 is offline   Reply With Quote
Old 04-29-2014, 01:23 PM   #2
avolnek's Avatar
It can be done. I actually did it to my first older pop up and pulled a jet ski with it...
Not the best of ideas but it can be done.
Be sure to have a hitch welded in properly to the frame of the camper. Also make sure what ever you plan to add to the back doesn't offset too much tongue weight...
I added brakes to both the jet ski trailer and the camper. I also had sway control installed on both!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 04-29-2014, 01:27 PM   #3
Thanks. The weight issue was my big concern. I wouldn't be using it for a lot of weight. It was just a thought I had if it could be done or not.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
Old 04-29-2014, 01:28 PM   #4
The trailer has electric brakes and I do have a sway controller as well.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
Old 04-29-2014, 01:28 PM   #5
avolnek's Avatar
May actually be easier for you to install a roof rack for bikes though.
I actually pulled the existing bumper off the pop up and installed a new bumper with 1/4" steel walls and welded to the frame for the hitch...
Old 04-29-2014, 01:30 PM   #6
That's probably more than I want to get into. Thanks for the info.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
Old 04-29-2014, 02:20 PM   #7
KMP44's Avatar
When you say back of the camper, if you mean the bumper - no. A popup's bumper isn't going to be designed for the weight of bikes. Frame - maybe, but not the bumper.
Not sure what you tow with, but we have a bike rack that has a square tube base that slips over the hitch between the ball and the receiver on the tow vehicle. Slide it on, tighten one bolt, done. Works well and we put 3 bikes on it.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 04-29-2014, 02:23 PM   #8
hitch
I asked about a bike rack for my rockwood 1940ltd pup but did not get any replies but the reviews of the ProRac bike rack on this site were very positive. It is attached to the front trailer area on the frame. It does run $300-400 so not cheap but mayve better choice than welding a frame in the back?
Ringbill is offline   Reply With Quote
Old 04-30-2014, 07:12 AM   #9
GalsofEscape's Avatar
For what it is worth, rockwood (and i bet the others as well) does not recommend putting a bike rack or hitch on the back of the popup. Will probably effect your frame warrenty if you are still under it.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 04-30-2014, 08:22 AM   #10
Thanks for the thoughts. Sounds like something I should not do.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
hitch
