Old 05-30-2011, 04:00 PM   #1
hole in roof, best way to repair?
Hi everyone,
This weekend, we had the pop up out, and a gust of wind flipped the porch awning over the top of the camper, and the awning frame where the poles fold into popped a hole in the roof of the camper, about 1/2 x 1.5 inches. It looks like a thin layer of fiberglass over styrofoam insulation. The foam is dented, but not that bad. What would be the best way to repair it? Do RV dealers sell repair kits? Should I use some type of advesive caulking and fill the hole in? Right now we put duct tape over it to feep water from getting in.
I think its a 228D with a slide out, can't remember the model, we don't keep it at our house. We bought it new last year. I think the next step is to replace the plastic ball and sockets for the awning poles with metal brackets of some sort, something a little stronger.
Any help would be much appreciated
t-berd is offline   Reply With Quote
Old 05-30-2011, 04:08 PM   #2
papap's Avatar
I would fill hole with foam. Then level it off after it dries. Then redo the fiberglass. You can get the fiberglass repair kits at any auto parts store.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 05-30-2011, 04:14 PM   #3
sherdep's Avatar
there might be a couple of ways to repair the spot -
you will need to lightly sand the area around the hole so the resin will have a place to adhere to you may need to a small glass mat with epoxy resin the spot and then put some Gel-Coat over it to repair.
or depending on how big the repair (for a small repair)
Another idea could be to fill the hole with silicone and then use epoxy resin over it to fill and then gel-coat it -
you are probably gonna get a bunch of diffrent ideas on a fix for this one and how big the repair would be depends on how big and deep the hole is.
they also make a repair kit for Marine application which could fix your spot as well - if I remeber it is called Marine -Tex . it is a two part mix just like you would do with the epoxy resin and hardener.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-30-2011, 04:39 PM   #4
It really isn't that big or deep. There is a small spot maybe as big as a penny where you can see the foam underneath, and the foam is dented maybe 1/4 inch at it's deepest. The rest is a crack about an inch or so. Since it's new, I really want it to look nice, ideally so you don't notice it unless you are looking for it. Thanks for the replys so far.
Old 05-30-2011, 05:25 PM   #5
sherdep's Avatar
if it is as small as you say it is then Marine Tex will do the trick with minimal work. The hardest part will be blending it - if all else fails go to a marine store and look thru their fiberglass repair kits - am pretty sure you will find something that will work
Old 06-02-2011, 01:15 PM   #6
take it to an reputable auto body shop ... no foolin around.
d-mo
D-mo is offline   Reply With Quote
Old 06-02-2011, 08:39 PM   #7
j2detroit's Avatar
i had the same poblem a few years ago but only made one home about the size of a nickle i cleand it up real well and filled it up with a silicone adheasive put a couple layers into it so as not to get to much bulid upsmoothed out each apllication anb feathered the last one into the top looked great and lasted great
j2detroit is offline   Reply With Quote
Old 06-07-2011, 11:23 PM   #8
Sea Goin', POXY PUTTY Hard to find but worth the effort.
Politicians should be required to wear uniforms like NASCAR. At least the TAXPAYERS would know who their corporate sponsors are !
Squall Line is offline   Reply With Quote
