Old 06-13-2016, 09:41 AM   #1
Hot water drain
Have my HW-276 for two years, this weekend after two days, no problems, hot water started coming out of, drain tube located right rear of unit. I think these tubes have something to do with winterizing, something here in central Florida we are unfamiliar with.any ideas what's causing this condition ???
GB guy is offline   Reply With Quote
Old 06-13-2016, 09:49 AM   #2
Herk7769's Avatar
The cap on your hot water low point drain is either leaking or fell off.
HAM CALLSIGN - KC3FFW
Old 06-13-2016, 09:56 AM   #3
SeaDog's Avatar
Check your faucets I though I had a low point drain leaking and it turned out to be a leak at the faucet running down the water line and out the low point drain
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-13-2016, 04:28 PM   #4
My low point drains on my hw276 don't have caps. But in the cabinet at the back. The low point shut valves are in there u might have an open valve or broken valve.
kinma13 is offline   Reply With Quote
Old 06-14-2016, 07:56 AM   #5
Thanks, my drain tubes don't have caps or are threaded to receive a cap, I'll check inside my cabinet
Old 06-14-2016, 09:33 AM   #6
On my Flagstaff 27SC the low point drains are on the floor in the cabinet next to the rear bed. They were pretty susceptible to damage and occasionally getting bumped and leaking. I cut a plastic toilet flange in half vertically and screwed it to the floor in front of the drains, kinda like a wall around them. No problems since then.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 06-14-2016, 10:39 AM   #7
Cabranch47 any pics? I just cover mine with a pot upside down.
drain, hot water, water
