Old 04-22-2014, 06:17 PM   #11
delb2917's Avatar
Yeah both hot and cold are going in the same direction. Away from the pipe and bypass in going with the pipe.
Sent from my SCH-I535 using Forest River Forums mobile app
delb2917 is offline   Reply With Quote
Old 04-22-2014, 06:18 PM   #12
markb5900's Avatar
You got it then.
Your hot water tank is bypassed in this position.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 04-22-2014, 06:19 PM   #13
delb2917's Avatar
So with both hot and cold shut off that won't let water in water tank then. If Im thinking right.
Old 04-22-2014, 06:21 PM   #14
markb5900's Avatar
You have it exactly right.
The blue (cold) is the incoming water and the red (hot) is the outgoing.
You have them both turned off now, and the line between them allows the water to pass through so to speak without going in your tank.
Mark B
2017 GMC 3/4 Ton TV
Old 04-22-2014, 06:23 PM   #15
delb2917's Avatar
Got it. Thank a bunch. I will be takin a bunch of pictures this weekend. I will share with all who helped me through this first time experience.
Old 04-22-2014, 06:25 PM   #16
markb5900's Avatar
We all had the first time of trying to figure this stuff out.
Glad we could help
Mark B
2017 GMC 3/4 Ton TV
Old 04-23-2014, 04:13 PM   #17
delb2917's Avatar
Now I have another question. I have de winterized my pop up. Now I am ready to flush out the hot water tank. So im assuming I open both hot and cold water lines and let the water from my holding tank go through the tank and pull the plug to let it drain out all old water or other liquids?
Old 04-23-2014, 04:49 PM   #18
markb5900's Avatar
Yes, just make sure you turn the bypass valve so it is "off".
Then you can fill up the hot water tank and drain it if you want.
Don't have it on when you drain it.
Mark B
2017 GMC 3/4 Ton TV
Old 04-23-2014, 04:54 PM   #19
Canadian Member
itat's Avatar
Reverse all 3 valves to close the bypass and open the hot and cold lines from/to the water heater.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-23-2014, 04:57 PM   #20
delb2917's Avatar
Ok. I will do that. Thanks a lot markb5900. You have helped me out tramendesly. And everyone else.
hot water, tank, water, water tank
