04-22-2014, 05:44 PM
Hot water tank
Can someone tell me which way the hot water tank bypass needs to be up or flipped horizontally when I am flushing out all my anti freeze from winter?
Sent from my SCH-I535 using Forest River Forums mobile app
04-22-2014, 05:45 PM
I have a mac pop up 2012
04-22-2014, 05:52 PM
Purge your lines in the (Winter Position),then place in (Summer Position) to fill the W/H. The Bypass line should be closed and the H&C open to tank for Summer use! Youroo!!
04-22-2014, 05:54 PM
I don't know your camper at all, but as a general rule.
If the valve is parallel with the water line, it is open, if it is at 90 degrees to the water line it is closed.
Mark B.
2021 GMC 1500
Anderson WDH
04-22-2014, 06:01 PM
on mine there are 3 valves and the valve handles points in the same direction as the pipe when open and form a t when closed. Until you get clear water out all the faucets, both hot and cold, don't touch the bypass so you don't get antifreeze in the hot water tank. Once you get this close the bypass and open the other 2 valves on mine.
04-22-2014, 06:08 PM
Ok my bypass is making a t. My other ones are going with the pipes. So I can turn water pump on now and and flush all the anti freeze out? And it won't go in my hot water tank?
04-22-2014, 06:11 PM
Can you take a pic of them.
I think you have it backwards right now but not sure.
Your bypass should be OPEN (parallel) and the others closed (T). But I am not positive of your set up.
Mark B.
2021 GMC 1500
Anderson WDH
04-22-2014, 06:13 PM
Ok I turned the hot and cold to make a t and the bypass going with the pipe.
04-22-2014, 06:15 PM
Ok
The red valve is in the right position, put the blue one in the same, can't tell from the pic what it is in.
The valve with teh red and blue connection should be parallel with the hoses, it looks like it is.
That will bypass your hot water tank.
Mark B.
2021 GMC 1500
Anderson WDH
04-22-2014, 06:17 PM
Yeah both hot and cold are going in the same direction. Away from the pipe and bypass in going with the pipe.
04-22-2014, 06:18 PM
You got it then.
Your hot water tank is bypassed in this position.
Mark B.
2021 GMC 1500
Anderson WDH
04-22-2014, 06:19 PM
So with both hot and cold shut off that won't let water in water tank then. If Im thinking right.
04-22-2014, 06:21 PM
You have it exactly right.
The blue (cold) is the incoming water and the red (hot) is the outgoing.
You have them both turned off now, and the line between them allows the water to pass through so to speak without going in your tank.
Mark B.
2021 GMC 1500
Anderson WDH
04-22-2014, 06:23 PM
Got it. Thank a bunch. I will be takin a bunch of pictures this weekend. I will share with all who helped me through this first time experience.
04-22-2014, 06:25 PM
We all had the first time of trying to figure this stuff out.
Glad we could help
Mark B.
2021 GMC 1500
Anderson WDH
04-23-2014, 04:13 PM
Now I have another question. I have de winterized my pop up. Now I am ready to flush out the hot water tank. So im assuming I open both hot and cold water lines and let the water from my holding tank go through the tank and pull the plug to let it drain out all old water or other liquids?
04-23-2014, 04:49 PM
Yes, just make sure you turn the bypass valve so it is "off".
Then you can fill up the hot water tank and drain it if you want.
Don't have it on when you drain it.
Mark B.
2021 GMC 1500
Anderson WDH
04-23-2014, 04:54 PM
Canadian Member
Reverse all 3 valves to close the bypass and open the hot and cold lines from/to the water heater.
04-23-2014, 04:57 PM
Ok. I will do that. Thanks a lot markb5900. You have helped me out tramendesly. And everyone else.
