11-29-2011, 07:11 AM
How do you drain the water lines?
Hi everyone, I have a 2011 Rockwood HW 296. I was wondering how you drain the water lines after hooking up to city water? I cant find a low point drain valve anywhere. Do you pull the anode in the hotwater heater? Any help would be appreciated.
Cal
2013 Rockwood Premier 2516G
11-29-2011, 08:46 AM
We have a 2011 Lexington motorhome. Our drain valve is under the bed. Not the most convenient but better than under the motorhome I suppose. We Just lift up the bed to get to the storage space and there it is.
11-29-2011, 10:22 AM
you can locate the low point drains on most RVs, by finding the drains underneath and following them back to where the valves are.
my low point drain valves are just above the drains, inside under the sofa.
11-29-2011, 05:12 PM
The HW 296 is a pop-up correct?
In my pop-up the low point drains are under the sink close to the interior wall right behind the converter.
They are close enough to the interior wall that I didn't know they were there until I went under the camper looking for them for winterizing and found the outlets. I saw about where they should be and had to feel around for them because I could not see them through the small access door.
There was one for the hot line and one for the cold. They had the same type of valve as the hot water heater bypass valves.
I wish I knew THAT earlier in the season
Hope it helps
11-30-2011, 04:57 AM
I appreciate the responses! I should have added that it is a popup.
11-30-2011, 05:41 AM
Mine are also under the sink inside the cabinet. My last camper I had to look all over for them and found them on the underside rear of the camper. Usually after a camping trip, I pull the anode from the HW heater and open the drains and open the sink faucets to allow air in the lines so the water can drain better.
2021 Apex Nano 191RBS OFF GRID
2017 Chevy Colorado Z71 4x4 3.6 L
12-07-2011, 10:23 PM
I have a Rockwood HW276 and the "low point drain" is actually the same as the fresh water drain. It's under the city water inlet and at the side of the fresh water tank under the camper. As far as the hot water tank, mine has an anode tube which doubles as the hot water plug. I had to go out and buy an 1 1/16 inch socket to be able to open it and drain it. After relieving the pressure first, I simply removed the plug and let the water drain. I rinsed off the anode tube and replaced/rescrewed it back on. Let me know if you need more info since your model is very close to mine.
P.S. I store mine in the garage for the winter.
12-08-2011, 05:56 AM
Thanks Vcarbona,
I started digging around more and found two drain holes underneath that was flush with the floor. I followed that up inside the cabinet that my tv stand was on directly behind the city water inlet. I had to cut a little piece out of the buffer board in the backside of the cabinet space, and there were two T handles attached to the hot and cold water lines. I pulled up and the water started to drain. I still have to pull the anode rod to get water out of HWH. When you pull the anode, does the water drain out of your filter?
12-09-2011, 02:55 PM
Well as I said the hot water heater drain also has the anode tube attached to it. It's essentially one of the same. I'll see if I can send you a pic of where it's located.
12-09-2011, 03:30 PM
I will post some pictures also to compare. Thanks.
12-09-2011, 10:24 PM
Can you use the air blower adapter and blow them out with an air compressor?
2007 Cherokee 28A+
2007 Dodge Ram 2500 5.9 CTD 6spd 4x4 Quad Cab
www.dogandtrailer.com
12-10-2011, 10:15 AM
Yes we can do that to hot and cold water lines but the water inside the hot water heater should be drained and the anode tube inspected and replaced if necessary. I'm not sure it's a good idea to air blow the water inside the hot water heater out with a compressor unless it's to clear out the water lines between tank and the bypass valves and even then I would do that with hot water heater tank plug off to allow the air pressure to escape. My worry would be that the hot water tank could be filled with air and the air pressure could cause something to crack inside the tank.
12-10-2011, 05:38 PM
The round thing on the bottom center is the hot water tank plug and anode tube. Get a socket wrench and unscrew to drain and also to reveal the anode tube.
12-11-2011, 03:31 PM
You will need to drain the filter separately. Be carfel not to "spill" when unscrewing the jar. I don't really have room to put much of a pan under it when unscrewing it, and the area below it is an area that they ran carpet to, so I have to be VERY careful. I then bypass the filter by disconnecting the lines going to either side of it, and connecting them together with a plastic double male that I picked up at the local hardware store.
Then when I pump the pink-stuff through the system, I'm not using half a gallon to fill the filter jar, plus I don't have to worry about spilling again in the Spring. I've heard of others that fill the jar with washed stone or marbles to minimize using the extra anti-freeze, but for me, it's just easier to bypass.
In the Spring, I may buy the three valves and the fittings that I'd need to plumb a bypass on the filter, but that's a low priority project.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
12-15-2011, 06:16 AM
Fire Instructor,
Wow! I got down and took a look at my filter and you are right! This is going to be a challenge unscrewing it without getting everything wet.
12-19-2011, 03:07 PM
Mostly Harmless
I used a silicon baking pan to catch any spills. It's flexible enough to get under the filter and rigid enough to hold it if I do spill. Also it was a place to let the filter drain once I got it out.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
12-19-2011, 04:43 PM
Originally Posted by CundiffClan
Fire Instructor,
If the lines are drained and subsequently depressurized, it shouldn't be too bad. Just have a rag handy to clean up spills. After loosening the filter with the water filter wrench, use both hands to unscrew the filter until it comes off to minimize spillage.
12-19-2011, 05:19 PM
Thanks for the suggestions everyone! When the camper gets back from shop, I'll do a winterizing test run.
