Old 05-19-2018, 02:50 PM   #1
How full is my water tank?
Has anyone invented a device to tell you how full your tank is when boondocking? We are on our 2nd season with our Rockwood Freedom 2318g PUP and are venturing out on some boondocking trips. This was the first trip and I was worried about overfilling the tank with the potable water hose from the park spigot so I stopped earlyó way too early as we didnít even have enough to fully flush the winterizing stuff out. The dealer told us to look underneath and make sure the bladder wasnít bowing because that means itís too full but IDK maybe Iím looking in the wrong place that seems kind of hard to tell. I was thinking of some kind of external gauge thatís linked to a float indicator or something? Any ideas?
Pom_Mom1993 is offline   Reply With Quote
Old 05-19-2018, 02:51 PM   #2
your tank should have an over flow that tells you when it is full with out hurting a thing. Fill it till water comes out then stop.
Kimber45 is offline   Reply With Quote
Old 05-19-2018, 02:55 PM   #3
Thanks Kimber45 the dealer warned us not to do that because it was too much strain on the brackets that hold the bladder...
Old 05-19-2018, 03:04 PM   #4
Iíd tell the dealer if it falls out YOU (dealer) will replace it under warranty. Ridiculous.
My17Ram is offline   Reply With Quote
Old 05-19-2018, 03:05 PM   #5
LOL fair! Newbie here obviously!
Old 05-19-2018, 03:38 PM   #6
kenandterry's Avatar
2nd season with your Rockwood huh?
How long is your warranty?
Did the dealer show you where the overflow vent is?
Anyone else on here with a Rockwood Freedom Pup that can confirm this bladder too full story?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 05-19-2018, 03:43 PM   #7
Grammar Pedant
67L48's Avatar
My fresh water tank was translucent and easily seen. I would just take a knee and look to see where my water level was. So, you could use that to complement the idea given above by just filling until it overflowed.
Another option would be to use 5-6 gallon water cans. Fill one. Then pour into your tank. Rinse and repeat and you can meter how much water it going in.
Another option would be to use a water meter on the hose. Here is an example of such a meter, though I have not used one myself. Anyway, you can simply watch in real time how many gallons are flowing.
So, there you go. You have four options. Fill to overflow. Watch the tank by viewing the water line on a translucent fresh water tank (if you have one). Use known volumetric water cans to meter the water. Use a meter on the filling hose.
The only ways to know how much water is remaining is to either do the eyeball check on a translucent tank or to measure the waste water (ensuring that you capture grey water in a tank). If you started with 20 gallons of fresh water and your 10 gallon grey water tank is about half full ... then you have around 15 gallons of fresh water remaining.
Good luck.
TV: 2005 F150, 5.4L, Tow Package, 4WD
Current RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 05-19-2018, 04:14 PM   #8
cavie's Avatar
It is ridiculous but it is true. There have been many pictures of tanks falling out on this forum. If I was traveling with mine I would not fill it till I got to my destination or close.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-19-2018, 04:54 PM   #9
M & A Camping's Avatar
Been camping for over 10 years, always filled fresh water before we leave. Never had problem, and in Minnesota there are alot of roads
M & A Camping is offline   Reply With Quote
Old 05-19-2018, 04:55 PM   #10
fonzie's Avatar
The brackets can let go if tank is filled completely and travelling....here is a an example.
2506S Water Tank Brackets Bent
Fonzie
tank, water, water tank
