Old 05-10-2013, 03:26 PM   #11
Is this the same process for a Roo 23SS? I'm a newbie. Winterized for the first time, and now we are de-winterizing for the first time. I'll take any help or step-by-step instructions that may exist.
A couple of questions. It looks like after flushing, we fill the hot water tank, and then santize the fresh water system. Do we completely fill the fresh water tank for the sanitization process, and then do we completely fill it again and flush it
vkwood is offline   Reply With Quote
Old 05-10-2013, 10:55 PM   #12
Kasimar1's Avatar
Thank you!
I just wanted to say thank you to everyone for all of your helpful advice. Im going to try and de-winterize my camper this weekend presuming the weather will cooperate. Really looking forward to our 1st camping trip of the season on Memorial Day weekend.
2005 Rockwood Premier 2302
2015 GMC Canyon Crew Cab 4x4 V6
Kasimar1 is offline   Reply With Quote
Old 05-15-2013, 08:52 PM   #13
Kasimar1's Avatar
I just thought of something regarding this process. What do I do with the antifreeze when I flush the system? Can I dump it down the sink drain in my house?
Old 05-15-2013, 09:17 PM   #14
Capt. Mike's Avatar
Yes, the pink anti-freeze is eco-friendly. Even easier, if you can do it, is to hook up your grey water tank to a sewer dump (like in a campground) and dump it while you are flushing the system.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 05-19-2013, 09:04 PM   #15
Kasimar1's Avatar
Is there a trick for putting the drain plug back in for the hot water heater? I appear to be doing something wrong because I can't seem to get mine back in. Does it screw back in the normal way?
Old 05-19-2013, 09:15 PM   #16
Yes, it just screws back in. Just check and make sure that both sets of threads are not damaged, and that you aren't cross threading it.
Wildwood 26TBSS
Dodge Ram 2500 / Cummins Diesel
jrs_diesel is offline   Reply With Quote
Old 05-19-2013, 09:32 PM   #17
Kasimar1's Avatar
Also, is the end of the rod supposed to line up with something inside of the water heater? I'm wondering if that is part of my problem.
Old 05-19-2013, 09:56 PM   #18
Herk7769's Avatar
No, but gravity is not your friend when trying to get the threads started.
You have to hold the anode "level" while trying to start the threads.
HAM CALLSIGN - KC3FFW
Old 05-19-2013, 10:00 PM   #19
Rebel702's Avatar
No the rod is suspended inside the HW tank. Try cleaning the threads with WD40. I also use teflon tape on the threads for a good seal.
Also, remember to flush the outside shower since it will also have anti-freeze.
<I see Herk got the answer posted as I typed.>
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-20-2013, 11:59 AM   #20
Kasimar1's Avatar
I cleaned the threads and applied Teflon tape to the threads. I agree that gravity it not my friend and that is why I'm finding it hard to screw it in. I also need to go out and buy a socket to tighten it up (1 1/16 size I think).
