Old 05-20-2013, 01:59 PM   #21
Herk7769's Avatar
Originally Posted by Kasimar1 View Post
I cleaned the threads and applied Teflon tape to the threads. I agree that gravity it not my friend and that is why I'm finding it hard to screw it in. I also need to go out and buy a socket to tighten it up (1 1/16 size I think).
Yep!
HAM CALLSIGN - KC3FFW
Old 05-21-2013, 08:38 PM   #22
Kasimar1's Avatar
Well I got the drain plug in (finally). Although I noticed it sticks out ever so slightly, just enough so I can see 1 row of threads. Is that right? I don't ever recall how it was before. I switched the bypass switch and the tank filled with water and is not leaking, so I imagine it's in correctly.
2005 Rockwood Premier 2302
2015 GMC Canyon Crew Cab 4x4 V6
Kasimar1 is offline   Reply With Quote
Old 05-21-2013, 09:16 PM   #23
Herk7769's Avatar
Yes, it does not go in all the way. Just snug it up so it does not leak under pressure. The Teflon will keep it sealed.
Huh, I don't have a good photo of one seated with the threads showing.
Need to rectify that.
Old 05-21-2013, 09:41 PM   #24
Kasimar1's Avatar
Oh good. Sounds like I got it right. I did notice something weird though. When I turned on the hot water faucet with the hot water heater bypass turned off and the water pump on, the pump was acting kind of unusal. Is it because it's both filling the hot water tank and building up pressure at the same time?
Old 05-21-2013, 10:15 PM   #25
dsagal79's Avatar
Send a message via Skype™ to dsagal79
No, you need to turn your water bypass back to the pump. Right now it is set to suck in the rv anti freeze. Switch the valve near your pump and it will work normally.
dsagal79 is offline   Reply With Quote
Old 05-21-2013, 10:19 PM   #26
Herk7769's Avatar
Most likely it is fine. If it does not turn off then you may have a suction side air or pressure side water leak.
Old 05-22-2013, 08:22 PM   #27
Kasimar1's Avatar
Iíve been following the process that is described here as posted by mTn_biKer65
De-winterizing your RV (and yourself!)
I think the part where Iím confused is where you put the hot water heater back into service. Is the purpose for this part of the instructions to check for leaks? I guess I donít understand why you canít do the same with the city water hooked up.
