Old 04-07-2015, 10:47 AM   #1
Hw27sc slide out not level
We are on our first trip with our new flagstaff hw27sc. We noticed the slide out dinette is not level. We might have had 550 lbs on it total. It's probably inch or so lower on the outside. I double checked and the trailer is level front to back and side to side. Has anyone else experienced that on any of the highwall campers?
nomadvagabond is offline   Reply With Quote
Old 04-07-2015, 11:02 AM   #2
Mine also has a slight "list" when opened. One thing that helped minimize it was to lift and pull out after you think that it is fully extended. Mine comes out a little more, it does not correct all of the sag but helps some. I wish I could find a way to easily adjust/lubricate the slide mechanism.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 04-07-2015, 06:05 PM   #3
exploreco's Avatar
Our non high wall does this too. We noticed it when we picked it up new doing the walk through. Mechanic said they all do that. He showed us other new ones on the lot that where also like that. Doesn't seem to feel off from sitting on the inside. He said what ever you do, do not try and level the slide. You will end up causing problems.
2014 Rockwood Premier 2514G
2010 Ford F150 Lariat
Nights Camped in 2018-??
2017-29, 2016-33, 2015-22, 2014-22, 2013-20
exploreco is offline   Reply With Quote
Old 04-07-2015, 06:10 PM   #4
Thanks for the reply. That makes me feel much better.
slide, slide out
