Old 06-18-2015, 07:36 PM   #1
wstensgaard's Avatar
HW296 Battery Drain
Hi all!
Noticing that the battery is drained after each storage. Is there something inside that we are forgetting that is draining the battery? Thanks in advance.
wstensgaard is offline   Reply With Quote
Old 06-18-2015, 07:53 PM   #2
your C\O and propane detector are still running. Either disconnect battery manually or use\install battery kill switch.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-18-2015, 07:57 PM   #3
Thanks. I figured so much but wanted to make sure I wasn't missing something.
Old 06-18-2015, 07:58 PM   #4
Nothing that you can do much of anything about. Either disconnect the cable from your battery when not in use, or install a battery disconnect switch. I'm partial to the Blue Sea systems, but there are a slew of them that would work for you.
rana is offline   Reply With Quote
Old 06-18-2015, 08:15 PM   #5
bikendan's Avatar
I don't know of any popup that comes with a battery disconnect switch.
It's an aftermarket install.
If you don't keep it plugged into shore power, the parasitic power drains will empty a single battery in just a few days, without a disconnect switch.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-18-2015, 09:33 PM   #6
f5moab's Avatar
My popup came with a 30A inline fuse. When not camping, and leaving the batteries in the boxes, I pull the fuse. Works great, never had a problem!
Red circles are the inline fuses; bottom one is the main fuse for the trailer, other fuse is for the second battery.
f5moab is offline   Reply With Quote
Old 06-19-2015, 04:35 PM   #7
GalsofEscape's Avatar
Agree with f5moab, pull the 30amp in line fuse. Or keep it plugged into to shore power if you are able. Either way will work.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 06-19-2015, 10:58 PM   #8
Thanks everyone. My husband has been pulling the batteries and putting them in a trickle charger. Will use one of the options suggested.
Old 06-20-2015, 04:28 PM   #9
I just disconnect the 2 wires from negative terminal anytime I am done camping
Sent from my SCH-I545 using Tapatalk
2018 Flagstaff Micro Lite 23LB
Equalizer 4 PT. WDH 1k/10k
2012 Jeep Grand Cherokee V8 4x4
jk70 is offline   Reply With Quote
Old 06-20-2015, 10:54 PM   #10
I have a battery tender from harborfreight that cost $4.99on sale, I installed double plug (one that cannot be plugged in reverse) put solderless connectors on the two wires and attached to the battery, then all I have to do in plug it into a 15 A plug and it keeps the battery topped off. When leaving I just unplug it at the battery and put the power supply up in the shop I also have one on everything else around the farm that has a battery.
2002 Rockwood Freedom 2318G
2004 Ford F 150 5.4 liter
3 Chihuahuas Sammy, Delilah,Gypsy
nineoaks2004 is offline   Reply With Quote
battery, drain
