Old 07-06-2015, 08:15 AM   #1
HW296 Black water?
Best way to clean after lowering the pup down?
lakecumberland is offline   Reply With Quote
Old 07-06-2015, 08:20 AM   #2
None really. I use a hydro flush clear but not really sure that helps much. You could use a flush king but not sure if that would help much either. We try to use full hook up sites. You could get a blue tote and clean it at home if you have a dump station close home get at least a 36 gal so you could clean it at least 2 -3 times. Empty at CG dump first.
kinma13 is offline   Reply With Quote
Old 07-10-2015, 06:14 PM   #3
Ttt
Old 07-10-2015, 06:34 PM   #4
Originally Posted by lakecumberland View Post
Ttt
Why triple posts and what is Ttt?
Old 07-10-2015, 07:16 PM   #5
Just a bump to see if anyone else has any input. Many people are busy right now and may had missed it earlier. Sorry if I abused the rules. Ttt = to the top.
Old 07-10-2015, 08:54 PM   #6
HONDAMAN174's Avatar
Two different ways when I had my HW 277. If we had hook ups and before we lowered the roof, we would put our rinse wand thru the canvas and in the camode to rinse while draining. If no hookups and roof down, dump the tank first and get a gallon bucket and put under valve. Put rinse wand up the valve and run until bucket fills. Take to toilet and empty bucket. Repeat. Wear gloves.
Valterra A01-0187VP Flexible Tank Wand https://www.amazon.com/dp/B000BGHYE8..._CAhOvb2HJPDK1
Tip: secure the rinse tip by putting a screw thru it. I have had it come off inside the tank more than once. Might also use a few extra holes for water flow.
Just glad to get away
black, black water, water
