Old 06-08-2015, 03:57 PM   #1
Hw296 door?
When I go to install the door there is a gap at the top I have to force the closures on it. After tearing down yesterday I noticed one has stripped out. What to do to fix the problem?
lakecumberland is offline   Reply With Quote
Old 06-09-2015, 12:54 PM   #2
The gap could be caused by it not being level and the roof is leaning away from the door. The strip out can be repaired by using a plastic anchor and some really good adhesive. Could also be "overuse" of the stabilizer jacks.
Trevor43 is offline   Reply With Quote
Old 06-09-2015, 08:27 PM   #3
Kinda what I figured.
Old 06-09-2015, 09:24 PM   #4
HONDAMAN174's Avatar
I usually left the top ones loose anyways cause when you let out the awing it will shift the roof away from the door anyways
Just glad to get away
Old 06-10-2015, 08:40 PM   #5
If I leave the top loose it leaves a big gap.
Old 06-10-2015, 08:56 PM   #6
That fine. In the summer, it lets out excessive heat and in winter you can run a buddy heater and have adiquit ventilation!
door
