07-15-2015, 12:55 PM
HW296 garage fit ?
Hey all!
New to this forum, as we are seriously considering purchasing a 2014 Rockwood HW296...question is, will it fit in our garage?! We are having trouble locating specs for the exact closed length/width, please help! I am so excited, I can hardly stand it - but I want to make sure it will fit in our garage before we buy it. Our garage measures 19'5" (door to wall) & 17'4" (wall to wall). Thank you!
07-15-2015, 01:01 PM
is that the only thing you are looking to put in the garage?
"Camping invloves a tent, bugs, and incliment weather. This aint camping"
-Bill Thomas
Palomino Solaire 317 BHSK
07-15-2015, 01:06 PM
Georgia Rally Coordinator
Welcome to the forum. Try web site for your model camper. should have dimensions. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-15-2015, 01:36 PM
according to forestriver it is 21' 4" when closed with hitch.
http://www.forestriverinc.com/brochu...tcbrochure.pdf
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
07-15-2015, 01:40 PM
I'm in the same boat. Bringing home a new to me 2013 Flagstaff HW27KS this weekend. Yes, the length is 19'4". My garage is at about 19'6". I am more concerned about the height. My garage has a standard 7' high door. With the ac, its going to be tight. Worse case scenario, I have to get a low profile ac installed. I am not sure about width. I have seen 7' and 7'9". I am not sure which is accurate.
07-15-2015, 02:10 PM
Yes, will have to be...except for water heater & garage fridge.
07-15-2015, 02:14 PM
1st off, I love your happy faced beer cheers! I was mistaken, husband did find measurements...i misunderstood his quandary. I guess he isn't sure of the angle of the hitch...or something like that. He thinks it will fit by a mere margin, but will touch.
07-15-2015, 02:15 PM
Thank you! We think it will fit, but just barely, if we go diagonal with it.
07-15-2015, 02:19 PM
Congrats! I read somewhere on this forum that people let a little air out of the tires to lower the pup to make it fit in the garage. Can I ask what the difference is between a Flagstaff HW & a Rockwood HW? This is our 1st with any kind of travel trailer...all I know is like the ones w/ a toilet, shower, & walls around the potty.
07-15-2015, 02:42 PM
I was in the same situation a few months back with my HW296. The 21' 4" is pretty darn close to accurate. My issue came in with the height. The specs show 72" closed height, but that does not account for the AC. I made a couple modifications on my garage to make it fit. First, I cut back the trim on the outside of the garage, in the shape of the AC unit. Next, I have to prop up the actual door, while in the open position, to gain more clearance. Finally, I have to deflate the tires about half way, and then once in, inflate them again for storage. Hopefully, this helps and you end up getting the unit!
07-15-2015, 06:37 PM
flagstaff and Rockwood are twin models. The only difference is interior colors..... have many great trips with your new camper
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
07-15-2015, 07:19 PM
How wide are the HW models?
07-16-2015, 05:17 PM
I have not tried putting my HW in the garage. I think it would fit fine. I know Rockwood is using the low profile A/C units by Coleman Mach 3. They save a good 6" of height. That is genrally all that people needed to fit it into a garage.
Good luck.
I think the widht is around 83".
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
07-16-2015, 05:53 PM
I know length it will not go but going diagonally might work. Not much else going in there though
07-16-2015, 09:34 PM
We had a 2010 Rockwood HW276 and with our 22' deep garage we had 2' of clear behind and 6" at the tongue for the garage door to close (19.5' long from ball to bumper). Pretty sure the 296 is about 2' longer.
As for height it cleared the garage door by 2" and that was scotching the door as high as it would go. Good luck. Loved our HW! Traded it two weeks ago on a TT.
Gypseedaddy
07-19-2015, 05:07 PM
My HW 276 clears my opening height by 1"!! Since the stairs from the laundry room are on that side, I had to knock 1 picket from the railing to have room for the bumper......close!
07-19-2015, 08:11 PM
It is a good thing they use the low profile A/C units now. It gives us just what we need to clear the garage opening.
Vin.
2015 HW296
2013 Chevy Tahoe
07-19-2015, 08:48 PM
Any garage door repairman will be able to adjust your spring tension and motor travel to bring the door out of the opening. Not a job for an inexperienced person. There is a LOT of energy wound up in that spring! No additional parts should be required. Pushing up on the door could cause the cables to unwind from the spools causing the door to come crashing down or twisting in the opening. (21 years in that business, saw a lot of messes).
Also, I once owned a boat on a trailer that was too long for the garage. There was a simple fix that involved a good welding shop cutting the tongue, installing a hinge that allowed the cut-off to swing to the left when parked then come back solidly pinned in place for towing down the road.
I have not checked but I would bet you could find that mod on You-tube.
An idea to explore!
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
