Old 10-08-2014, 09:50 AM   #11
The gray should leak and no it has no over flow if the tank fills youll get over flow in the shower thats how you know the tank is full. Sounds like you have a leak at a fitting or a crack somewhere. It should be covered under the warrenty if you have one. (Not sure new or used)
kinma13 is offline   Reply With Quote
Old 10-08-2014, 09:51 AM   #12
Sorry shouldnt leak
Old 10-08-2014, 10:57 AM   #13
HONDAMAN174's Avatar
Check the "y" connector where the shower drain meets the pipe. That's where mine cracked.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 10-18-2014, 08:51 PM   #14
Hey, thanks for the hint. Crawled under the trailer this weekend, sure enough the y connector is cracked, right across the top of it. Seems to me too much stress may have been applied during assembly.
mlachiw is offline   Reply With Quote
Old 10-18-2014, 08:58 PM   #15
Now the "fun" part- replacing it!
I cut off the other two connections CAREFULLY not to get into the other pipes. Unhook the grey valve pipe and hanger and reinstall that last.
water
