Originally Posted by pmorris1
I have a 2013 HW296. Can anyone tell me where the hotwater by-pass valve is located, and how you get to it. Also is there a low point water drain for hot and cold on this camper,and if there is where would i find it.
Hw heater by pass is directly behind Hw heater.
I'm not familiar with your unit but access is normally behind a false panel that will need to be removed from the inside of camper.
Wherever your Hw heater is on the outside go to the inside of your camper and open a cupboard door or drawer to access it.
Your dealer should have showed you this.
Your low point drains should be on bottom of camper ones red and ones blue.
Ron
