Old 10-16-2015, 06:24 PM   #1
Jjmark
Hw296 rockwood 2016 water filter
Got new camper this fall. We are trying to Winterize and can't figure out where the water filter is to remove if. Help!
JoniNelson is offline   Reply With Quote
Old 10-16-2015, 06:47 PM   #2
GoGators904's Avatar
Under the cabinet next to the TV! Or at least that's what I think the guy showed me during walk through!
GoGators904 is offline   Reply With Quote
Old 10-16-2015, 06:50 PM   #3
Grn_Mtns's Avatar
Likely to be near pump and behind a plywood panel to keep stuff from falling on it. . If you have a filter think about replacing it. Search threads for filter housing issues We do not have that style camper but good luck!
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 10-16-2015, 08:21 PM   #4
Jjmark
Thanks. We took the panel off and found the water heater and bypass valves. We did not see a filter but when we got the camper there was a filter in a bag. We figured it was a spare replacement but maybe they never installed it to begin with. Will look a little better tomorrow
Old 10-16-2015, 08:39 PM   #5
I've heard if FR even put them in the cabinets. Mine us next to the heat tank n pump by I have a hw276
kinma13 is offline   Reply With Quote
Old 10-16-2015, 08:55 PM   #6
Left Coast
Is the spare you have just a filter, or the housing also?
Old 10-17-2015, 05:16 AM   #7
Our water filter never stopped leaking so we just took it out.
lakecumberland is offline   Reply With Quote
Old 10-17-2015, 08:49 AM   #8
Jjmark
Thanks Bob, it is just a filter and a large plastic white wrench
Old 10-17-2015, 09:09 AM   #9
JoniNelson, the filter case should be empty the filter u found should be what u would but in if u decide to use it.
Old 10-17-2015, 09:17 AM   #10
Jjmark
Ok we just need find the filter case Just so I know what I am looking for......what color is it?
rockwood, water, water filter
