Old 08-29-2014, 12:31 AM   #11
Pill Billy's Avatar
Originally Posted by kinma13 View Post
didnt read that pill billy thank you ill have to look into that pre filter. yeah i dont even use the filter i have a filter on the white hose and i use that same hose to fill the fresh tank. in the spring i plan on figuring out how to bypass the filter cause water fills up the canister and then sits untill i use the tank again.
Research "Pex" or "shark bite" tubing/parts. I'm afraid of my stock filter leaking all over the electronics. For now I have a one gallon zip lock bag with 2" slits down the side seams. I'm able to put the filter inside the bag and still zip it up while the hose sticks out of the sides.
If I decide to keep it for future use I may end up getting one of those battery operated basement water sensors and throw it in the bag. If I decide to remove it permanently I can the bag will capture the leaking water when I unscrew it.
Pill Billy is offline   Reply With Quote
Old 08-29-2014, 05:11 AM   #12
raspivey's Avatar
I looked at a 296 a little more than a year ago before deciding on something else. That may very well be the pump switch, but I seem to recall the switch for the LED floor lighting in about that area.
Old 08-29-2014, 06:43 AM   #13
vinmaker's Avatar
I never installed the water filter when I had my HW256. I just figured if one uses an outside filter then why bother. Also. how the heck can you replace it. Looked like a small specialty part that would be hard to find = expensive. I wish it was not even there. Takes more antifreeze to fill it up.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-29-2014, 02:04 PM   #14
W4NT3D's Avatar
Yup it's the water pump, filled the water tank, turned faucet with little water, turned on switch, faucet water is powerful.
2015 Rockwood HW296
2014 Silverado 1500 LTZ
W4NT3D is offline   Reply With Quote
Old 08-29-2014, 07:20 PM   #15
vinmaker's Avatar
cool. one switch down. lol
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
