Old 08-28-2014, 06:51 PM   #1
W4NT3D's Avatar
HW296 Switch?
What does this on/off switch on the left do?
Name:	ImageUploadedByForest River Forums1409269764.181035.jpg
2015 Rockwood HW296
2014 Silverado 1500 LTZ
W4NT3D is offline   Reply With Quote
Old 08-28-2014, 07:23 PM   #2
vinmaker's Avatar
Hmmm. Where is that switch? I think it might be the water pump switch for your fresh water. I think that because the hot water switch should NOT be by the front door. It should be within the unit for safety.
You should have a master on/off switch by the door for lights and fan.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 08-28-2014, 07:46 PM   #3
W4NT3D's Avatar
Vin,
Yeah those switches are are located near the floor near the tv cabinet. I think your right it may be the water pump switch.
2015 Rockwood HW296
Old 08-28-2014, 07:52 PM   #4
vinmaker's Avatar
Go ahead and turn it on. It will not hurt it to run it dry for a bit as it is a self priming pump. You should hear it turn on. then kill it.
2015 HW296
2013 Chevy Tahoe
Old 08-28-2014, 08:05 PM   #5
The left if the water pump. DONT run it dry you can burn up the pump. You only need to turn it on if you have water in the fresh tank and ur not connected to a water supply.
kinma13 is offline   Reply With Quote
Old 08-28-2014, 08:17 PM   #6
vinmaker's Avatar
True Kinma. Do not run it long. It will not hurt to kick it on. But if you do not feel comfortable then just wait until you winterize to test it out.
Vin.
2015 HW296
2013 Chevy Tahoe
Old 08-28-2014, 08:21 PM   #7
Pill Billy's Avatar
I wouldn't run it dry either to prevent potential problems. In my unit the pump is located behind the rats nest of wires behind the converter.
I'm not sure how to do the yearly maintenance on the pump to clean the pre filter. It's a tight hole to work in and I don't like the thought of electrical so close to water.
Pill Billy is offline   Reply With Quote
Old 08-28-2014, 10:19 PM   #8
Yeah pill billy FR decided to install the water filter in the same location as all the electric. Filter is right beside circuit n fuse panel.
Old 08-28-2014, 10:27 PM   #9
Pill Billy's Avatar
I'm not so worried about the water filter. Behind the WFCO converter/distribution panel is the water pump. The pump has a pre filter that requires annual maintenance per the owner's manual. There are a zillion wires back there is a huge mess.
Old 08-28-2014, 11:53 PM   #10
didnt read that pill billy thank you ill have to look into that pre filter. yeah i dont even use the filter i have a filter on the white hose and i use that same hose to fill the fresh tank. in the spring i plan on figuring out how to bypass the filter cause water fills up the canister and then sits untill i use the tank again.
Old 08-29-2014, 12:31 AM   #11
Pill Billy's Avatar
Research "Pex" or "shark bite" tubing/parts. I'm afraid of my stock filter leaking all over the electronics. For now I have a one gallon zip lock bag with 2" slits down the side seams. I'm able to put the filter inside the bag and still zip it up while the hose sticks out of the sides.
If I decide to keep it for future use I may end up getting one of those battery operated basement water sensors and throw it in the bag. If I decide to remove it permanently I can the bag will capture the leaking water when I unscrew it.
Old 08-29-2014, 05:11 AM   #12
raspivey's Avatar
I looked at a 296 a little more than a year ago before deciding on something else. That may very well be the pump switch, but I seem to recall the switch for the LED floor lighting in about that area.
Old 08-29-2014, 06:43 AM   #13
vinmaker's Avatar
I never installed the water filter when I had my HW256. I just figured if one uses an outside filter then why bother. Also. how the heck can you replace it. Looked like a small specialty part that would be hard to find = expensive. I wish it was not even there. Takes more antifreeze to fill it up.
2015 HW296
2013 Chevy Tahoe
Old 08-29-2014, 02:04 PM   #14
W4NT3D's Avatar
Yup it's the water pump, filled the water tank, turned faucet with little water, turned on switch, faucet water is powerful.
2015 Rockwood HW296
Old 08-29-2014, 07:20 PM   #15
vinmaker's Avatar
cool. one switch down. lol
2015 HW296
2013 Chevy Tahoe
