Old 07-20-2015, 09:33 PM   #1
HW296!! X Chock & Andersen Leveler??
Anyone use these? If so do you use a pair? Also anyone use the Andersen Leveler? Looking to lighten the load with wood blocks.
lakecumberland is offline   Reply With Quote
Old 07-20-2015, 10:20 PM   #2
Wobbles's Avatar
I use the Anderson levelers on my TT and like them. I also keep a stack of Lego type Lynx levelers for those grades where you only need a slight lift and for the crank down stabs when I need to go high on the Anderson levelers.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 07-21-2015, 03:10 PM   #3
I switched to the Lynx Levelers (legos) from carrying wood blocks when we went from a PUP to an A-frame. Like the Lynx far better than the wood blocks for storage and weight - mine came in a pack of 10 with a cloth carrying case at Wal-mart for $30.
I put a bubble level calibrated in inches on the front of the A-frame. 1" on the level equals 1 lego. Back approximately into position, read the level, put the number of legos indicated, and back on to the legos. It really is as simple as that.
Fred W
2014 Rockwood A122
2008 Hyundai Entourage (minivan)
Old 07-21-2015, 08:12 PM   #4
vinmaker's Avatar
I use two X-Chocks on my HW296 and love them. I always had sway with my single axle HW but the HW296 with the X-Chocks is rock solid. I love them.
For levelers.... I still use wood.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 07-22-2015, 11:46 AM   #5
I use Andersen leveler so and X-chocks and love them both.
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 07-22-2015, 01:53 PM   #6
x-chocks really tame down the trailer movement! Highly recommend them. Would not own a Rockingwood without them!
walljammer is offline   Reply With Quote
Old 07-22-2015, 03:03 PM   #7
BOBFIDY's Avatar
X chocks and Lynx levelers. A great combo.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 07-22-2015, 10:19 PM   #8
Rivnut
Rivnut's Avatar
+Andersen levers are good on gravel or hard surfaces, but I had to dig them out of the ground when it got wet last trip, keeping a board handy.
I have legos for sale !!!
Rivnut is offline   Reply With Quote
Old 07-23-2015, 12:15 AM   #9
GreenImp's Avatar
Send a message via MSN to GreenImp
I chose Roto-Choks over X-Chocks, so I cant help you there other than yes, you will want a pair of them.
For leveling, I went from wood blocks, to strips of horse stall mat, to Andersen Levelers. Andersen Levelers ARE all they're hyped up to be.
I did find that when I only need an inch or so to get level, I prefer using something other than the Andersen's. I cut one of my stall mat strips into a few small pieces about the size of those plastic lego blocks. I can use the rubber block by itself if only an inch is needed, and I can use it under the Andersen Levelers if I ever need a little more lift then they offer. The stall mat strips actually worked great for leveling and they are indestructible but I went to Andersen Levelers to save space and weight.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 07-23-2015, 02:30 AM   #10
Just a member
kandl's Avatar
Deploy the X-Chocks at every stop - luv em. Have the A-Levelers too but haven't had to use them yet. Been batting a thousand with level sites.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
