Old 02-27-2012, 11:37 PM   #1
Increased Battery
I have a 2011 Rockwood 232XR and I do mostly dry camping. I want to increase the battery capacity from the 70 or 80 AH I have with the deep cycle that came with the unit. I was thinking of getting a couple of 6V golf cart batteries and wiring them in series and hooking them up instead of the old battery.
Will I need to do anything else to my trailer or will this do the trick? Also, will my converter charge these okay?
Thanks for the help.
Any other advice would be appreciated.
Hujipher is offline   Reply With Quote
Old 02-27-2012, 11:39 PM   #2
flyrotor's Avatar
There are a lot of people that do just that, make sure they are still mounted where they will vent properly. Your converter should be just fine with the new setup.
flyrotor is offline   Reply With Quote
Old 02-28-2012, 06:28 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Either a pair of 6V or a pair of 12V Trojan batteries will do you well. The 12v would be better in some ways due to the fact if you have one fail you still have useable voltage. Not so with the 6 volters. You pay premium money for Trojan bateeries, but you get what you pay for with them. And your converter will have no trouble with them.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 02-28-2012, 09:06 AM   #4
You will not be disapointed in the Trojan batteries. I am running two Trojan SCS225's. They have an AH rating of 130 each. Double that and that is all I ever need. They are expensive but well worth it. I just recently paid $340 for a pair of them. I like dual 12 volt for a couple reasons. If I loose one battery I am still good to go with the remaining battery. I also occasionally use them for the trolling motor on my boat. I have been through many different brands of batteries over the years and none have matched the Trojans. I had 5 years on the Trojan on my last travel trailer and it was still going strong when I sold it.
rkswyo is offline   Reply With Quote
Old 02-28-2012, 09:18 AM   #5
Titleguy's Avatar
Also be aware that a lot of the 6v batteries are taller than your 12v ones and may not fit in the battery boxes you have.
Titleguy is offline   Reply With Quote
Old 02-28-2012, 09:22 AM   #6
Deep cycle batteries come in all different sizes. Some are designated by Group size, like group 24, 27 and 31. Basically, the larger the battery the more amp hours you get. Depending on your needs and the amount of space you have available, there are several options when it comes to batteries.
You can use one 12-volt 24 group deep cycle battery that provides 70 to 85 AH.
You can use two 12-volt 24 group batteries wired in parallel that provides 140 to 170 AH. Parallel wiring increases amp hours but not voltage.
If you have the room, you can do what a lot of RVers do and switch from the standard 12-volt batteries to two of the larger 6-volt golf cart batteries. These pairs of 6-volt batteries need to be wired in series to produce the required 12-volts and they will provide 180 to 220 AH. Series wiring increases voltage but not amp hours.
If this still doesn’t satisfy your requirements you can build larger battery banks using four 6-volt batteries wired in series / parallel that will give you 12-volts and double your AH capacity.
In my case with the 2 Trojan SCS225's I am getting 260AH. This is better than I can get with a pair of 6 volts and I have no desire to carry four batteries. (Cost and weight prohibitive and I don't have the room)
Old 02-28-2012, 09:32 AM   #7
Triguy's Avatar
I have a pair of Trojan T-145s in series for 260Ah. Your converter will be fine charging these as long as they are hooked up correctly with one issue. The converter probably doesn't go up to the 14.8 volts that Trojan wants so a separate charger is a good idea. My converter only charges up to 14.2 volts.
I bought a bigger battery box to fit both in the tray and allows for the extra height of the batteries. Its a tight fit so measure appropriately. Others have had to modify their trays to work.
I also put in a battery disconnect, of course. These batteries are very heavy and I didn't want to have to take them out once I had them in.
Speaking of which, I used a battery puller to lift them in. Very handy device. You can get one at an auto parts store for about $15 if you need one.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-28-2012, 09:34 AM   #8
IMHO on a TT where you are going to only have two batteries you would be far better off capacity wise to get two 12VDC deep cycle batteries. Remember two 6 volt batteries are just one 12 volt battery in a large package. The current available in each 6V battery is not multiplied. So if you have two 100 amp 6 volt batteries, you still only have one 100 amp 12 volt battery. Whereas if you have two 100 amp 12 volt batteries, you now have 200 amps.
Old 02-28-2012, 09:52 AM   #9
Triguy's Avatar
Donn - the problem that I ran into with two 12 volts is the size of the 12 volt vs 6 volt bank and the additional cost to the 12-volts.
Trojan T-145 6 volt in series offer 260Ah. They are 10 3/8" long, 7 1/8" wide, and 11 5/8" high. Total weight is 144lbs.
Trojan T-145 12-volt in parallel offer 280Ah. They are 12 7/8" long, 7 1/8" wide, and 11 11/16" high. Total weight is 156lbs.
My tray would never allow that much length and I didn't feel like modifying it. Granted this might not be an issue for the OP.
The 12-volt bank would have cost $150 more. Hard to justify.
Scott
2012 Shamrock 233S
Old 04-01-2012, 07:37 PM   #10
If you were going to choose 1 12V battery to get the maximum storage capacity which one would you get. The Trojan SCS225 looks good with its specs. We are usually pretty good about conserving power and I really don't want to added expense and tongue weight to have two batteries.
I'd love to put one really good battery and maybe a solar system on the roof to not necessarily recharge the battery fully every day but maybe added enough back in to extend the trip 1-2 days.
RobertGreenlee is offline   Reply With Quote
battery
