Old 09-06-2016, 06:35 AM   #1
Interior Mold/Mildew
We have a 2002 Rockwood Premiere Pop-up tent trailer. The previous owner put Thompson Water Seal on the interior. There is mildew on the interior fabric on the sides by the beds. I have tried various products to no avail. When I spray anything on it just runs down and I am assuming that is because it has Thompson Water Seal on it.
Does anyone have any product suggestions on how to remove the mildew?
Donna H. is offline   Reply With Quote
Old 09-06-2016, 10:52 PM   #2
I had mold on the canvas beside both beds. I tried everything. Even carpet cleaner. Nothing worked. Then I tried the mold / mildew remover from bass pro shops. That stuff worked like a charm. However, mine had not been water proofed by the P.O. I would give this stuff a try even if you have to order it on line.
Bass Pro Shops Mildew Stain Remover | Bass Pro Shops: The Best Hunting, Fishing, Camping & Outdoor Gear
Charger is offline   Reply With Quote
Old 09-07-2016, 02:27 AM   #3
Thank you
Thank you Charger. We have a Bass Pro Shop about an hour away from us so next time we are up that way we will stop in to pick some up. Hopefully that will do the trick as, we too, have tried many things. Thanks again!
We did clean the vinyl exterior this past weekend. I have to say Oxi Clean in a bucket of water and a good rinse afterwards worked like a charm. The vinyl took on a total transformation...it is now white again.
Old 09-07-2016, 05:03 AM   #4
Oxyclean can work on the inside also.........You will want to put some type of UV block spray/protectant on the outside.............makes future clean ups easier.
Trevor43 is offline   Reply With Quote
Old 09-17-2016, 03:41 PM   #5
Mildew Remover
Purchased the Bass Pro Shop Mildew Remover and was amazed at how well it worked. Had tried other products, but this one has removed all of the mildew and the inside of the trailer looks new again!! Thanks for the advice
mold
