Old 04-01-2014, 04:16 AM   #11
mlangdn's Avatar
Make sure the green switch is off and the red switch for 12v is on when running the battery.
mlangdn is offline   Reply With Quote
Old 04-01-2014, 04:20 AM   #12
mlangdn's Avatar
The white one is usually a ground. I think the blue is for trailer brakes and the black one is for twelve volt. It originally had a 7 pin harness. I would find someone close that knows more about that than me.
Old 04-01-2014, 05:47 AM   #13
Incheon, S. Korea
BigBaron's Avatar
Here's a great link to wiring. White is usually ground on an RV trailer, and black is positive.
trailer wiring
You'll have to chase the wires back to where they originate to verify though, as someone has fiddled with everything.
There often is an in-line fuse on the positive side of the battery wires. Mine was underneath the trailer!
Also check the fuses in the voltage converter inside the trailer.
If you have a DMM, use it to see if you have any direct shorts to ground.
The no~shock~zone by Mike Sokol is recommended reading, too.
I hope this helps!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 04-01-2014, 06:00 AM   #14
PapaSmurf's Avatar
I too would guess some dope cut off the 7 pin plug to opt for the lesser 4 pin flat you are holding. If you have a utility trailer shop in your area they can you get the correct plug back on your unit and get it wired correctly.
It is not difficult, the seven pin plug you buy normally has instructions about which wire goes were.
If you have a Tractor Supply Store in your area they are a great resource for purchasing all your wiring needs like this.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 04-01-2014, 06:08 AM   #15
PapaSmurf's Avatar
Oh!, and just so you know you have contracted a virus that has a normal life cycle progression... tent, pop-up, travel trailer, 5th wheel, motorhome. Once you have contracted the virus you are hooked for life, there is no cure. And if you are lucky, you pass it on to your children.
Old 04-01-2014, 10:48 AM   #16
Are you talking about for running the fridge or in general just being on battery power?
I don't think I'll be running the fridge at all when on battery only just so we don't kill it too fast.
uphoto is offline   Reply With Quote
Old 04-01-2014, 10:50 AM   #17
I think I'll be looking for a 7 pin harness today and rewire it. They cut it off after the harness plug on the tongue so it's pretty easy to see where everything is originally.
Thank you everybody for all the great info and PapaSmurf I know it's a sickness but it's something I'm willing to deal with for the wellness of all the human race
Old 04-01-2014, 10:58 AM   #18
daydreaming about camping
jeeplj8's Avatar
typically there is a main fuse between the battery and the "house" side of the trailer. Odds are good the fuse is blown. Could be in the power center inside.
Though - with the creative wiring going on with the plug, maybe someone cut something inside they should not have.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 04-01-2014, 12:20 PM   #19
bikendan's Avatar
does your popup have electric brakes?
if so, you'll need the 7-pin connector and a brake controller.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-01-2014, 12:23 PM   #20
uhhh well......I don't know... haha. I have no idea on how to tell if it does.
newbie, pop up
