Old 05-09-2016, 03:40 PM   #1
Cowboy6201's Avatar
just opened my HW296 for 1st time for season
2010 HW296
My interior lights and fantastic fan not working after opening camper for the season, they were working when i closed it up for the winter.
Any ideas?
Tried everything even checked fuses all are good.
I even checked the roof safety switch.
Cowboy6201 is offline   Reply With Quote
Old 05-09-2016, 03:53 PM   #2
Is your battery charged?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 05-09-2016, 05:33 PM   #3
Cowboy6201's Avatar
Yes it's fully Charged.
Old 05-09-2016, 05:55 PM   #4
Cyber Phrenologist
Radio's Avatar
For additional info... do ANY of your 12 volt systems work? (Furnace, fridge, slides, TV)
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
Old 05-09-2016, 07:33 PM   #5
bikendan's Avatar
Probably bad plunger switch.
Old 05-11-2016, 07:15 AM   #6
Wolverine 1945's Avatar
Do you have a battery cut-off switch ???
Wolverine 1945 is offline   Reply With Quote
Old 05-11-2016, 09:49 AM   #7
jkoenig24
"Probably bad plunger switch."
I agree.
jkoenig24 is offline   Reply With Quote
Old 05-12-2016, 06:23 AM   #8
No answer from the Cowboy ???
Did not know we were talking about a Pop-Up !!!
Old 05-13-2016, 12:49 AM   #9
Cowboy6201's Avatar
No not that I'm aware of, no battery switch.
I have to check the plunger switch.
already found the GFI popped when I 1st opened it, no power from any of the 110 outlets.
now those are working after resetting GFI.
I'll have to test plunger switch next.
Good thing I found it last fall before I closed it up, I had no idea where it was, till I happened to find it on the outside of the roof just behind the lip of the inside of the roof.
In my old StarCraft it was on the push out, when you folded the wooden folding board the cushion rested against, when folding it down it would push the switch down.
Old 05-14-2016, 12:05 PM   #10
Cowboy6201's Avatar
Ooooppppppsssss found my problem wire wasn't even crimped in place on the plunger switch, fixing it now.☺
