Old 04-13-2015, 08:08 AM   #11
loumichelle735's Avatar
Slightly off your topic but I wanted to get your thoughts on elk neck. We are heading there in July. Like you it's not too far for us.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
loumichelle735 is offline   Reply With Quote
Old 04-13-2015, 08:14 AM   #12
f5moab's Avatar
My auto valve on my 228 works; so long as you remember to open both valves after you park. But, it is advisable to purge both lines. I guess the short line from the tank to the valve needs to be purged. So the dealer told me that after disconnecting and filling; make sure to open each valve separately and make sure the lines are purged.
From experience, when my fridge is on propane; no batteries required. I believe requiring 12V is model specific. It is also non-auto. If you run out of propane, your fridge cuts off.
Need to know the type of battery. If it is a small starter battery it won't last long.
f5moab is offline   Reply With Quote
Old 04-13-2015, 11:46 AM   #13
jw34's Avatar
A nice peaceful drive for us coming from Reading PA. Very little highway other than 12 miles on I 176, and 6 miles on Rt 1. Other than that, Rt 10 & Rt 272 are peaceful 40-50mph rides through the countryside and farmland.
272 will take you thru the quaint town of NorthEast MD. About 10-12 miles north of the park. Make sure you visit the town for the small shops on Main St. And don't miss out on Woody's Crab House on Main St, Steak & Main on Main St, and The Nauti Goose next to the marina. Excellent food at all three places.
The park itself is a bit uneventful. There's only one loop with full hookups (Northeast Loop). And there are a few other loops with views overlooking the Chesapeake. Well, it's actually the Elk River right there, but you can see where it meets the Bay. If you find a campground map, I was in Elk loop site #138. The pad was about 30' from a cliff edge dropping down 40' to the water. And you'll see the occasional tugboat pushing barges up the river towards the Delaware Canal.
Would be a great spot if you're a fisherman. But I don't fish, so....
No alcohol allowed in the state park.....but what happens in the pup, stays in the pup.
Also make sure to visit the lighthouse at the southern tip of the peninsula. Beautiful view of the bay. And on the west side of the peninsula, the SP has a beach, although it and the camp store don't open til Memorial Day.
The site pads are a firmly packed gravel type surface and are fairly level.
I know some people go to private campgrounds with activities for the kids and to socialize with the other campers. That's not me, I'd rather be in a quiet nature setting to recalibrate my stress-laden brain, with an occasional jaunt out for local seafood. Elk Neck served that purpose for me.
Due to the time of the year, there were only about a dozen sites occupied when I was there. All on the end of the loop overlooking the water. One other pup, a TT, a 5er, and a handful of tent campers. They didn't bother me too much, but the wife gets annoyed at the sound of a gnat farting. So the pet-friendly loop had a few barking dogs, a few screaming kids, and a drunk cackling hag next door. All were easily drown out with the hum of a bunk fan.
Quiet hours are 11p-7a. I was usually asleep by 9p and up at dawn. The park is generally clean and the bathhouse in Elk loop was average in cleanliness. And I make those comparisons to others I've stayed at. The cleanest I've ever seen was the Northeast loop at Elk Neck in 2013, followed by Assategaue SP. The sloppiest I've seen was Cape Henlopen Sp in DE.
And don't expect any cell phone service, I have Sprint and was picking up one bar on good days.
I've got one more weekend excursion planned to Elk Neck in July, in the Northeast loop with full hookup, for the a/c.
'07 Chevy Silverado
'07 Chevy Tahoe
'11 HW27sc
jw34 is offline   Reply With Quote
Old 04-13-2015, 01:19 PM   #14
Thank you! I think I wish I booked that site. What a view. We also will be in NE loop in July. It's a straight shot down 272 for us from lancaster. We definitely prefer the state parks over others. Last Labor Day we spent at Point Lookout which was also nice if buggy. Thanks again.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
Old 04-13-2015, 05:36 PM   #15
flagst228's Avatar
Don't forget if u run out of propane and then switch tanks u need to get the air out of the system fist by lighting up a burner on the stove for a minute then try light the heater back up but make sure your fridge is off of LP and turned on 110 volts so it don't burn the propane
flagst228 is offline   Reply With Quote
Old 04-13-2015, 07:43 PM   #16
I just upgraded the Battery on my HW276 to two 100ah AGM batteries and built a battery box. I haven't had a chance to try it out yet but hope to be able to get 6 nights on battery.
ID:	74162   Click image for larger version
ID:	74163   Click image for larger version
ID:	74164   Click image for larger version
ID:	74165   Click image for larger version
Seanwain is offline   Reply With Quote
Old 04-13-2015, 07:53 PM   #17
f5moab's Avatar
You need to purge air out of both lines when first connecting or the auto feature will not work. To do that you connect both tanks, open one up, turn on stove, turn off stove. Close valve, then open second tank and turn on stove.
If you don't purge the lines the auto switch over will not work. I've done this every time I remove and install the tanks and never had it not switch over when needed.
Also, can't run 110AC when on battery power.
Old 04-13-2015, 08:01 PM   #18
f5moab's Avatar
They will keep you going for a while. Are those group 27 or 31? And where did you get them; chain store? I found a few places online and prices are over 300 bucks per battery...
Old 04-13-2015, 08:27 PM   #19
They are group 27's, I picked them up at Battery Plus and was able to get the manager to take $50 off each Battery.
Old 04-13-2015, 08:32 PM   #20
f5moab's Avatar
Never heard of them before (Battery Plus), but find out there is a store about 3 miles south of me that has them at a great price. I'll have to do some research. I was just getting ready to order some trojan, flooded deep cycles.
Thanks,
