Leaking water lines at the outside shower connection
My water lines are leaking where the fittings have clamped down going to the outside show connection inside the trailer. First time it was the hot line and I took it back to the dealer since it was still under warranty. They rigged up some kind of funky connection. It started to leak again. Now the other side is leaking. Anyone else have these connections leak before? How did you fix it. Appears to just be standard tubing and not pex tubing. Looks like shark type clamps from the factory which I took those off and put on regular clamps that you screw down but those leaks as well. Still trying to figure out a fix for this before our week long trip in a week.
Thanks!
2020 Rockwood Roo 235S
2010 Ford F150 Lariat
Nights Camped in 2021-?
2020-8, 2019-27, 2018-12, 2017-29, 2016-33, 2015-22, 2014-22, 2013-20
