Old 07-29-2013, 08:12 AM   #1
LED Bulb Replacements
We are picking up a 2014 Rockwood 2560G this weekend and I would like to immediately change out the bulbs to LED since we will be using it almost immediately dry docking. If I order the LEDs now I should have them in time. Is anyone familiar with this model or is there someplace where I can find out which ones I will need to order?
dmullen is offline   Reply With Quote
Old 07-29-2013, 04:22 PM   #2
Incheon, S. Korea
BigBaron's Avatar
LEDWholesalers on Amazon has good ones.
You have to get a tower/panel that has a minimum of 18 5050 LEDs to equal a normal incandescent bulb's 280+ lumens.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-29-2013, 04:49 PM   #3
HONDAMAN174's Avatar
I went with these in my TT. Really bright white light almost blue. Takes a little while to get used to from normal bulbs. Used to get a whistle from power convertor when 3 lights were on, now i can have them all on and no noise! Just remember when you plug it in and doesn't work, flip over the socket and try again.
NEEWER® T10 36 SMD LED Light Festoon Dome Bulb Lamp White 12V
http://amzn.com/B005J3BPCK
Just glad to get away
Old 07-29-2013, 04:54 PM   #4
Incheon, S. Korea
BigBaron's Avatar
That's the cool white color. You can get them in warm white (~4,500K) which is not as harsh.
Old 07-30-2013, 08:59 AM   #5
So the T10 Wedge Base 18x5050 SMD 12v Ac/dc 1441ww is a standard size bulb that will fit the light fixtures in the 2014 Rockwood 2560G?
I have three indoor lights and one outside light I need to replace with LED.
Old 07-30-2013, 11:01 AM   #6
The prices from this supplier seem rather high to me. I understand you are in a hurry but for those who can wait a few weeks for delivery you can save a lot of money by ordering them from exrell | eBay. I've ordered from here several times with no complaints. I changed over my entire 30' TT inside for about $15 including shipping.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 07-30-2013, 11:03 AM   #7
I'm not too worried about the price since I am on a time crunch. I'm just wanting to make sure these are the correct size. Also, which bulb would go in the out side light? 2014 Rockwood 2560G
Old 07-30-2013, 11:20 AM   #8
I believe it is an 1156
Old 07-30-2013, 05:58 PM   #9
Incheon, S. Korea
BigBaron's Avatar
I did A LOT of research into LED makers and their design. The Chinese ones are cheap. I bought some of all of them (12, 18, 20, 24, 28, 40 LEDs) so I could see for myself. I probably have 40+ different LED lights sitting in a box. The tower model I use was about $9, and not from LEDWholesalers (they were out of stock when I ordered). The quality is very good on these type of lights. I cannot risk getting something that will break because shipping to Korea is such a hassle and expensive. The stuff they sell here is junk, so that is not an option.
Some of the cheaper LED panels get VERY hot because they use a resistor, not an IC, to control voltage and current. Looking at them, they are CHEAP.
They work well for a lot of people, though, so to each their own.
I use aluminum foil tape as a reflector, and the tower-style are big, but as you can see in my picture, they do fit inside my overhead light fixtures.
Old 07-31-2013, 09:21 AM   #10
w4drr's Avatar
[QUOTE=BigBaron;434472]...Some of the cheaper LED panels get VERY hot because they use a resistor, not an IC, to control voltage and current. QUOTE]
Not to get too technical here, but what you say is true and can be a problem in an RV. By using only a resistor, instead of some sort of current regulator circuit, the LED's can get extremely hot when the converter goes into the bulk charge mode, which is on the order of 14.4V. I have read stories where the LED's actually de-solder themselves due to the heat build-up.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
led, replacement
